Engine Problem/replacement
So...
I found a
'97 Windsor with 202k for $300. (F150)
'03 Windsor with 140k for $550. (F150)
'97 from a Lincoln with 100k for 275.
I know the '97 would work, but is 202k miles too many to use as a "new" engine?
Will the '97 Lincoln engine work or would i spend too much on the labor during the swap?
I am not a mechanic.
Thanks
When you buy a used motor, the general rule is the lower the mileage, the higher the price. Go to Car-Part.com--Used Auto Parts Market and search for your motor. I've bought 2 5.4s recently off that site. Had both of them shipped from far and distant lands. One was $1225, 113k miles, 90 day warranty, and the other was $1025, 54k miles, 1 year warranty. The yards I dealt with, respectively, are Nordstrom's Auto Home and Certified Auto Recyclers They'll ship the motor directly to your mechanic, and you don't have to worry about core charges. AND, these 2 yards in particular don't use torches to remove their engines. Everything is unbolted and pulled properly. Nordstrom's run tests and documents if possible to give you a good idea of what you're getting.
Labor is going to be expensive any way you go. Getting a modular motor out of a 150 isn't the easiest thing to do. It's not the hardest, but it'll make you earn it for sure...
