Mark LT transmission filter for 4x4
Old Mar 10, 2017 | 11:10 AM
sgc2c's Avatar
sgc2c
There are too many choices at ford-parts.com to know which transmission filter my car takes. I've got the 2008 4x4 Lincoln Mark LT.
Which one does it take?
Old Mar 11, 2017 | 06:57 AM
projectSHO89's Avatar
projectSHO89
Assuming a 4R75E transmission, use the Motorcraft FT-105 for the main pan filter.
Old Mar 11, 2017 | 10:38 AM
alloro's Avatar
alloro
According to rockauto.com you only have 2 choices. See if one of them matches your pan configuration.
2008 LINCOLN MARK LT 5.4L V8 AT Oil Pan Gasket | RockAuto
Old Mar 11, 2017 | 10:41 AM
projectSHO89
Those are for the pan gasket, he asked for the filter.
The OEM gasket is reusable, it doesn't require replacement unless damaged.
Old Mar 11, 2017 | 10:48 AM
alloro's Avatar
alloro
I know he wanted the filter, I was trying to help him identify his transmission by starting with the pan configuration.
Old Mar 11, 2017 | 11:03 AM
projectSHO89
The Mark LT only got the 4R75E transmission unless he got a manual in which case he wouldn't have asked for a filter. There were no other options for an automatic other than the 4R75E.
Old Mar 12, 2017 | 11:50 AM
sgc2c's Avatar
sgc2c
Can I just use the Fram FT1167A? I lazily identified it on Amazon, which I sort-of trust.
They say it's a match.
Is there any animus toward Fram transmission filters here as there often is for the orange can of death oil filter?
Does the exact filter for the 4R75E vary depending on coolers and other diffferences?
Motorcraft also says the FT-138 and FT-147 are possible if it has "pump inlet filter" or "pump shaft strainer". FT-182 and FT-183 are choices if you have the "heavy duty aux trans oil cooler". So for Motorcraft, how can I possibly know??
Old Mar 12, 2017 | 12:12 PM
projectSHO89
There are people who hate anything Fram, others don't give a hoot, including me. If that is what Fram recommends, then it's probably their correct filter. I wouldn't trust an Amazon.com parts recommendation anyway, I've seen too many that are wrong.
No, there is only one pan filter.
None of those are pan filters. In some cases, filters like those might be replaced only if the transmission is rebuilt. You'd have to do your research to see if they're routine maintenance items or only for special events like a rebuild.
You're overthinking this. If you're going to do a fluid and filter change, just go do it. The Motorcraft filter is only $18 on Amazon, $40 at your local parts store.
Old Mar 12, 2017 | 12:59 PM
sgc2c's Avatar
sgc2c
Thanks, SHO89.
So you advocate for the FT-105. Interestingly, Amazon indicates that is NOT the right filter for the Mark LT (2008), so your suspicions of them are well-founded.
More interestingly to me, the FT-105 is the same filter for my 2005 Lincoln Town Car.
Does the Town Car really have the same transmission as a large truck? Amazing if so.
I'd never use the Town Car to tow anything, but perhaps I can.(?)
Old Mar 12, 2017 | 01:10 PM
projectSHO89
Go to fordparts.com and click on "Buyer's Guide". It returns 2,953 total applications ranging from 1996 to 2017 model years for the "FT-105".
The same filter is used on all of the transmissions based on the same basic design, there have been several generations of them over the last 20 years. It has nothing to do with the towing capacity (or lack thereof) of your Town Car.
BlackTruckDave
Oct 4, 2018 10:27 PM
Tom Evans
Jan 23, 2016 11:47 AM
OSBUCKEY
Oct 20, 2009 09:39 PM
linckeil
16
Sep 17, 2009 12:03 AM
nrvsreck
1997 - 2003 F150
Jan 6, 2006 04:32 PM
