Remove hub to replace rear brakes?
Old Mar 9, 2017 | 10:22 AM
mmfarms's Avatar
mmfarms
Trailering
I have a 91 F350 SRW. I have a Haynes book, and it says to replace the rear brake shoes the hub has to come off, since the F350 is considered the Heavy-duty drum brakes and the F250 and below are light duty. Anyone have any experience doing these?
Old Mar 9, 2017 | 10:43 AM
bbf385's Avatar
bbf385
No, you don't have to take the hub off to replace the drum or shoes.
Old Mar 9, 2017 | 11:48 AM
mmfarms's Avatar
mmfarms
Trailering
I see in your signature that you have an F250. My Haynes book says that you don't have to for the F250 but DO have to for the F350. Just clarifying that you personally know about the F350.
Old Mar 9, 2017 | 11:55 AM
andym's Avatar
andym
I've done both, but I can't remember which ones come off and which ones don't. I think it has to do with what axle your truck has. If I remember correctly (and it's fuzzy at this point), most sterling 10.25" axles you don't need to remove the hub, but with most Dana 80 axles you do. So if you have a fill plug on your rear diff cover, you probably need to pull the hub.
Again this is all from a few years ago when I worked on brakes a lot more. I'm sure someone will correct me if I'm wrong.
But all you need to do is remove both rear wheels from one side. It will be pretty apparent which style you have.
Old Mar 9, 2017 | 01:54 PM
ciamcoop's Avatar
ciamcoop
I have the sterling diff in my 93 f350 and I did not have to pull the entire hub assembly. Remover the tire and the drum should come off.
Old Mar 9, 2017 | 01:59 PM
andym's Avatar
andym
Did you have the sterling or Dana axle though? All F-250s got a sterling, as did all SRW F-350s (I believe). I've seen both in DRWs though.
Old Mar 9, 2017 | 03:57 PM
rla2005's Avatar
rla2005
Your 1991 F350 will have a Sterling 10.25" full floating axle. All you have to do is remove the wheel, then the drum. The hub can remain in place.
For reference:
F250HD models share the same Sterling 10.25" full floating axle with the F350 pickup.
The light duty F250s use a semi-floating axle version of the Sterling 10.25"
Old Mar 10, 2017 | 06:05 AM
tjc transport's Avatar
tjc transport
i ain't rite
^^^correct^^^
SRW brake drum slides off the studs. DRW the brake drum is pressed onto the hub.
Old Mar 10, 2017 | 06:17 PM
madpogue's Avatar
madpogue
Haynes manual information is always dodgy, esp. since they try to cover a wide range of years with one book. The info in your Haynes menu is probably from previous years that don't apply to your truck. Best to go by the FSM.
Old Mar 11, 2017 | 08:04 AM
krooser's Avatar
krooser
Pull your axles just for the heck of it... it will be fun!
f1501987
Apr 23, 2013 11:21 PM
KillerF250
Oct 11, 2006 08:51 PM
rbdutton
Jun 12, 2004 11:02 PM
missouguy
Apr 20, 2004 11:25 PM
csft
Jul 6, 2003 02:13 PM
