rear drum removal
Old Jul 1, 2003 | 09:22 AM
csft's Avatar
csft
rear drum removal
97 F250HD 10 1/4 rear
can the rear drum be removed without taking the hub with it?
I hate the idea of the state inspectors removing the hub to look at the brakes.
Old Jul 1, 2003 | 11:06 AM
jim henderson's Avatar
jim henderson
rear drum removal
That's a strange question. I think all the drums are removable without the hub. So I would guess you have a problem with a stuck drum.
On my F250 with I think the 10 1/4, easily allows the drum to be removed. Some drums will have a locking washer around one or more stud which may need to be removed. I haven't seen one of these lately but who knows.
Also you might need to turn the brake adjuster to loosen the shoes a lot before the drum will release. Or you might have rust which will usually respond to some moderate whacking with a hammer, or liquid wrench of a torch applied around the studs.
Good Luck,
Jim Henderson
Old Jul 1, 2003 | 08:44 PM
70spoiler's Avatar
70spoiler
rear drum removal
yes you can remove the drum with out taking the hub off.this started in 95.i have to assume you are talking about 3/4 or 1 ton.jack k
Old Jul 2, 2003 | 11:03 AM
csft's Avatar
csft
rear drum removal
Well I guess this weekend the WD-40 and the big hammer comes out.
Thanks
Old Jul 5, 2003 | 03:44 AM
csft's Avatar
csft
rear drum removal
They came off, thanks.
Now where do you get a tool to remove the brake shoe retaining spring?
I used a screwdriver but next time I would like to have the proper tool.
Old Jul 5, 2003 | 09:08 PM
steve83's Avatar
steve83
rear drum removal
Better parts stores sell it - I got one at a pawn shop.
Old Jul 6, 2003 | 12:27 PM
timjk69's Avatar
timjk69
rear drum removal
Actually Jim, my 1987 F-250 drums slide off the hubs also.
Old Jul 6, 2003 | 02:13 PM
rebocardo's Avatar
rebocardo
rear drum removal
Try northerntools.com Automotive catalog. They have a variety of brake drum tools, including spring plyers.
thalvorson
Nov 8, 2016 11:53 AM
Blue and White
Nov 17, 2015 05:52 PM
gravdigr
Jul 6, 2015 02:40 PM
carchub
13
Aug 7, 2014 03:27 PM
67lunargreen
Mar 2, 2009 11:08 AM
