DEF use
Old Mar 8, 2017 | 10:15 AM
17 Oaks's Avatar
17 Oaks
DEF use
5545 mi, have added 7.5 gallons of DEF.
Excessive, normal, will slow as I get more miles on it.
About 60+% of the miles on the truck are towing my 5th wheel. I generally drive about 65 on open Interstate, but drive with traffic (70-75) if I am slowing down the traffic.
Old Mar 8, 2017 | 10:17 AM
oklarado's Avatar
oklarado
Normally its about a gallon per thousand, but in my past experience pulling trailers you will go thru more, and you've towed quite a bit.
Old Mar 8, 2017 | 10:28 AM
ROADRUNNER1's Avatar
ROADRUNNER1
I had to fill up with DEF at about 4500 miles, so you did better than me. I had been towing quite a bit also.
Old Mar 8, 2017 | 10:31 AM
17 Oaks's Avatar
17 Oaks
Thanks guys
Old Mar 8, 2017 | 10:32 AM
skipcox's Avatar
skipcox
I thought the DEF tank only held 7 gallons??
Old Mar 8, 2017 | 10:33 AM
ROADRUNNER1
BTW, I used the Buccee's DEF in 2 gallon jugs for $2.49 per gallon. That is cheaper than filling at a bulk DEF station.
Old Mar 8, 2017 | 10:55 AM
fordmantpw's Avatar
fordmantpw
He didn't necessarily add all 7.5 gallons at one time...
Old Mar 8, 2017 | 10:56 AM
troverman's Avatar
troverman
I don't tow in the winter other than the occasional snowmobile trip. Used 5.5 gallons in 5,000 miles. I'd say you're very much in the normal range. I will say I believe these trucks use a bit more than the previous generation. My 2016 would go 5,000 miles on its 5-gallon tank, including summer towing.
Old Mar 8, 2017 | 11:27 AM
17 Oaks's Avatar
17 Oaks
According to Ford its 7.5 Extended Range: 2017 Ford Super Duty Long-box Crew Cab Carries More Fuel - The Fast Lane Truck
Correct, I add 2.5 gal at a time
Thanks and yes I think you are correct on previous generation going a bit further, my '15 would need an add right at oil change time and I was hauling heavy in that rig, while now I tow.
Old Mar 8, 2017 | 12:36 PM
PwerStroke99's Avatar
PwerStroke99
I have a little less than 1/4 tank of DEF left, and I am closing in on 7300 miles on my truck.
I need to find some cheaper DEF out there. I just paid $9.99 for 2.5 gallons from Napa here in Spokane.
Old Mar 8, 2017 | 12:47 PM
Top_Speed1's Avatar
Top_Speed1
In my past trucks DEF buying experience; $9.99 /2.5gal jug is quite reasonable, I've seen it all the way up to $14 out on the road at some remote fuel stations.
Bulk dispensing at truck stops can be much less, but I'm kinda weary of those.
Old Mar 8, 2017 | 12:51 PM
PwerStroke99
Good to know, thanks! my first DEF truck
Old Mar 9, 2017 | 07:52 AM
Top_Speed1's Avatar
Top_Speed1
In emergencies where you can't find it (usually there's a Wally everywhere tho, and sometimes they're NOT the cheapest!) don't forget the likes of in-town hardware stores like True Value. They usually are ~$10.99 on the 'Blue DEF' branded jugs as well.
I see WallyWorld is currently $11.97
I went into limp mode before on another make diesel, not fun when your pulling and on a tight schedule. So, don't go limp!
Old Mar 9, 2017 | 08:28 AM
17 Oaks's Avatar
17 Oaks
Tues I bought the 2.5 gal and it was $12.96. They now have an additional brand on the shelf and its $7.98 for 2.5
Old Mar 9, 2017 | 09:12 AM
EO2SeaBee's Avatar
EO2SeaBee
Don, the new Buc-ee's here are coming with DEF at the islands. Perhaps as the ones closer to you are renovated, you will have access there as well. The one near me just expanded by adding a new island with DEF (and Diesel) at the pumps, which they sell for $2.50/gallon and it is in underground tanks, rather than above ground tanks or totes.
