DEF use
Old Mar 11, 2017 | 08:53 PM
  #31
EpicCowlick's Avatar
EpicCowlick
Yup, DEF is injected only when combustion temperatures reach approximately 1,000 degrees. That happens way less often when not towing vs towing. That's actually a good report of what is expected.
Old Mar 11, 2017 | 11:19 PM
  #32
HRTKD's Avatar
HRTKD
Does your Superduty stink really bad during a regen? I had that happen twice today. My DEF gauge went down so I think it was the regen that made it smell so bad.
Old Mar 12, 2017 | 09:37 AM
  #33
17 Oaks's Avatar
17 Oaks
Originally Posted by troverman
Sounds good! I would like to come visit TX this summer as a road trip; we'll see if my schedule permits.
Come on down, its a big country....state. E of I 35 lot of farm land and the big Pines of E Texas, N Central, no trees in N Dallas because up there at one time Cotton was King. Up in the Panhandle its flat and farm country, head to the Central and its the Texas Hill Country, ranches and cattle, go S and its farms and cattle ranches all the way to the Gulf coast. Go far West and its the Permian Basis one of the worlds leading oil gas producing areas.
All of these areas have their own climate and look. Down South where I am at I have the best of both worlds, South Texas and the Hill Country, warmer than Austin, cooler than San Antonio.
So load up that dually and come on down, if I got the guest bedroom remodeled I will you put up. You can spend time in San Antonio which is celebrating its 300 hundred year birthday.
Old Mar 12, 2017 | 11:18 AM
  #34
coolidge54's Avatar
coolidge54
Originally Posted by AMXDREAMER
Texas in summer? You might want to rethink that! lol
I went to Texas in Feb, it was 92 degrees, I got a sun burn.
Old Mar 12, 2017 | 02:53 PM
  #35
frogracer's Avatar
frogracer
Originally Posted by fordmantpw
121 pumps? WOW!
Big stations around here have 8. Yes, 8 pumps, only half of which are diesel.
Here is the Buc-ee's under construction in Katy, TX at Cane Island Pkwy - don't know the official count of pumps but it looks to be over 100 as stated before. Hope they install a DEF pump island too...
Old Mar 12, 2017 | 03:42 PM
  #36
Davydee's Avatar
Davydee
Well... just over 600 miles towing and the DEF gauge shows less than 3/4 full. I may not make it to the first oil change. David
Old Mar 13, 2017 | 09:51 AM
  #37
troverman's Avatar
troverman
Thanks Don! I get 5 weeks paid vacation from my full-time job. I typically take a week at Christmas and maybe a day or two here and there. The rest I use to help me finish projects on my "side job" which is technical sloped field mowing. I just won a new contract with a municipality for this summer. So despite "wanting" to do something it might not happen. We'll see...but Texas sounds worth seeing!
Old Mar 13, 2017 | 10:14 AM
  #38
troverman's Avatar
troverman
Epic, I'm not sure that is entirely true. DEF is being injected almost any time the engine is running. It is true that hot, lean exhaust creates the most NOx which got VW into trouble, but hot and lean is how diesel runs the best and is most fuel efficient. Cummins, for example, specifies DEF consumption will be 2% of diesel consumption and they do not mention towing vs non-towing. From my experience, I changed my oil around 5,000 miles and refilled my DEF at the same time. I had the low DEF message showing. My lifetime fuel economy for that period was 14mpg. So, 5000/14 is 357 gallons of diesel. 2% of 357 gallons is about 7.14 gallons...which is right on part with the DEF gauge and what the dealer put in. So yes, you are correct that towing will raise EGT's which requires more SCR to control NOx...but let's be careful to not imply that DEF is not consumed during normal unloaded operation, even idling.
Old Mar 13, 2017 | 10:16 AM
  #39
troverman's Avatar
troverman
Yes, the truck will smell terrible when it is performing a regeneration. However, it has nothing to do with DEF. I believe no DEF is injected during a regeneration since the act of spraying water into the exhaust would lower the EGT, which is the opposite goal of a regen.
Old Mar 13, 2017 | 12:04 PM
  #40
EpicCowlick
Fair enough. I don't know how much DEF is injected when combustion temps are lowest but we do know that DEF is used at a much higher rate when the engine is really working. That was really my point.
Old Mar 13, 2017 | 12:30 PM
  #41
troverman's Avatar
troverman
Your point is totally solid, I agree. I was just clarifying that some DEF is injected even at idle.
Old Mar 18, 2017 | 01:32 AM
  #42
EO2SeaBee's Avatar
EO2SeaBee
I get that view each day going to and from work.
Here is the article about it in the Chronicle: Buc-ee's buys future I-10 travel center site in Katy - Houston Chronicle
Old Mar 18, 2017 | 01:34 AM
  #43
EO2SeaBee's Avatar
EO2SeaBee
How about ribs instead?
Old Mar 18, 2017 | 07:39 AM
  #44
17 Oaks's Avatar
17 Oaks
LOL I can identify...
My birthday present:
Old Mar 18, 2017 | 01:14 PM
  #45
wb6anp's Avatar
wb6anp
Had def refilled at about 4500 miles, oil life at 50%, the def was at 33%, I was at the dealer anyways for the third time for the same transfer case leak. Interesting my def gauge sat at about 50% for a long time then dropped to 33% in about 500 miles.
adgjqetuo
All Things Towing
Oct 3, 2018 02:25 PM
adbscu
Aug 15, 2016 05:45 AM
pdarby
Jan 22, 2015 11:06 AM
F16Vip3r
6.7L Power Stroke Diesel
19
Mar 24, 2014 11:28 AM
caddy
6.4L Power Stroke Diesel
Jul 12, 2011 08:58 PM
