Transfer case and diff fluid
Old Mar 8, 2017 | 08:20 AM
Mark_in_co's Avatar
Mark_in_co
I am getting ready to go through the truck and change all the fluids. Transmission, transfer case and front/rear diff's.
Transmission I've got covered, I've got a case of Mercon SP.
What are you guys using for the transfer case? Manual says Mercon but I can't find that any more. Are you guys using Ford's XL-12 transfer case fluid? Something else? Can I use Valvoline Maxlife ATF? It says Dex/Merc, assuming that means Mercon?
I was planning on using either Mobil 1 or Amsoil Sever Gear for the diff's. Any words of advice on either? Do I need to add additional friction modifiers to either for the rear? They both say they have it already.
Old Mar 8, 2017 | 09:54 AM
daddykitty's Avatar
daddykitty
I used Amsoil 75w-140 for the rear diff and did not need the friction modifier. Transfer case and P/S I use the amsoil signature series multi vehicle atf and front diff is 75w-90 if memory serves. You can check amsoils website to confirm your specific application according to what diif you have Dan 50, 60 or Sterling.
Old Mar 8, 2017 | 01:28 PM
raptor131's Avatar
raptor131
I just changed mine first time in 109k miles it was pretty brown, I used max life ATF if it is ok for our trans I assume it is fine for transfer case, my front diff was still golden honey consistency , after pulling fill plug and seeing how clean it was I reinstalled and left it alone
Old Mar 9, 2017 | 01:52 AM
bismic's Avatar
bismic
Royal Purple SynchroMax in the differential for me.
Mobil 1 synthetics in the differentials.
ganw
Feb 22, 2018 10:50 PM
Skauber
18
Apr 2, 2017 07:45 AM
parcours
Dec 22, 2016 10:03 AM
whitetmw
37
Jan 31, 2015 01:28 AM
sdeforest
1997 - 2003 F150
Mar 16, 2007 09:53 AM
