Sponsored by: Real Truck
atf transfer case
Old Feb 21, 2018 | 12:00 PM
ganw's Avatar
ganw
atf transfer case
2001 f250 stock automatic transmission
going to put Mobil 1 Synthetic ATF a multi-vehicle formula or Schaeffer Manufacturing Co. 0204SAT-006S All-Trans Supreme in stock transmission......good idea or bad idea?
On the transfer case what should I use......I have read about 5 thousand postings on several forums(I may have missed the one I should have read) some of them are very old
What is the current say so on using ATF in transfer case( IE one of the above) I think everyone is saying now use XL-12 from ford? Did something change in mobil 1 synthetic around the time xl 12 came out? I have been reading about people using mobil 1 syn in their transfer case for a decade now with evidently no problems so is it chemically different now?
Old Feb 21, 2018 | 09:21 PM
00t444e's Avatar
00t444e
I always use the cheap Walmart brand ATF in my transfer cases, never had an issue. You can use the more expensive stuff if you want to, but it is a waste of money in my opinion, transfer cases aren't that picky.
Old Feb 22, 2018 | 03:59 PM
speakerfritz's Avatar
speakerfritz
Im remembering reading right on the bottle of mobil 1 ATF"not to be used in transfer cases"
my transfer case requires a mercon V compatible fluid and Mobil 1 is not mercon V compatible.
Old Feb 22, 2018 | 05:46 PM
super 6.8's Avatar
super 6.8
The motorcraft transfer case fluid is not that expensive. Plus, you only need 2 quarts.
Old Feb 22, 2018 | 07:12 PM
00t444e's Avatar
00t444e
You can use Mercon, Mercon V, atf +4, or the expensive transfer case fluid, it really makes no difference the main thing is that you change it when you should.
Old Feb 22, 2018 | 10:50 PM
geekwithoutacause's Avatar
geekwithoutacause
YES on the mobil 1 synth in your transmission. Leave the Schaeffer snake oil out. Won't do a thing, complete waste of money.
Get the Ford stuff for the transfer case. You only need 2 qrts. do NOT USE MERCON V IN THE TRANSFER CASE.
dposey
1983 - 2012 Ranger & B-Series
Jul 16, 2019 07:44 PM
Skauber
18
Apr 2, 2017 07:45 AM
epoppe4
Apr 29, 2016 03:45 AM
PsD007.3
Feb 3, 2009 04:47 PM
pcguy760
Nov 20, 2008 10:48 AM
