Sponsored by: Auxito
Transfer Case Fluid
Old Mar 15, 2007 | 01:39 AM
sdeforest's Avatar
sdeforest
Transfer Case Fluid
What fluid is in our transfer case? Transmission fluid? Same as our automatic transmission? I'm on a maintenance kick on my 97 and that's something I have over looked. I need to change it, I've got 120k on my truck and I'm addressing things I've let go for to long. Speaking of things over looked, what weight lube goes in the front differential, same as the rear, 75w140 of just 80w90? Thanks for your help.
Old Mar 15, 2007 | 06:14 AM
triton54's Avatar
triton54
due to a newborn in the house , i went and had mine done but i know it tells you in your owners manual what to use for your specific truck.
Old Mar 15, 2007 | 07:21 AM
LxMan1's Avatar
LxMan1
Mercron atf in the transfer case.
Old Mar 15, 2007 | 08:04 AM
12swat's Avatar
12swat
I have a 97 with 4.6 4x4. Use Mercon ATF in the transfer case. I used synthetic ATF mercon (Mobil 1). I used semi syn 80/90 diff lube in the front diff. I used full synthetic 75/140 in the rear diff.
Old Mar 15, 2007 | 08:35 AM
rsylvstr's Avatar
rsylvstr
can you use Mercon V?
Old Mar 15, 2007 | 11:32 AM
preppypyro's Avatar
preppypyro
I used synthetic atf too, I dont see why you wouldnt be able to use mercon v either.
Old Mar 16, 2007 | 09:10 AM
KingRanchMan02's Avatar
KingRanchMan02
Originally Posted by triton54
due to a newborn in the house ......
Congrats!
Old Mar 16, 2007 | 09:45 AM
rsylvstr's Avatar
rsylvstr
i plan on using Mobil 1 Synthetic when i change over...including adding to my tranny when i drop the pan:
http://www.mobiloil.com/USA-English/..._Products.aspx
Old Mar 16, 2007 | 09:53 AM
sdeforest's Avatar
sdeforest
Thanks everyone, I'm changing out a rusty bumper right now. I'll do the transfer case and front diff. next. The only thing left is my headers. I would have that done if Ford didn't put the engine mount bracket over the exhaust manifold nut and stud, that's going to be a pain to get too and get off.
fishbones182
Dec 30, 2015 07:24 AM
bobcat518
Sep 20, 2015 07:20 AM
fordmerc
1978 - 1996 Big Bronco
Jun 29, 2015 08:35 PM
mklemin
May 7, 2008 02:31 PM
BGFNRED
Aug 16, 2005 07:03 PM
