Trans cooler
Old Mar 6, 2017 | 01:50 PM
56Jimmy's Avatar
56Jimmy
Trans cooler
Ok y'all here's an easy one. I bought an auxiliary trans cooler with a thermostat controlled fan. Does it matter which line I cut into for the install?
Old Mar 6, 2017 | 02:09 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Ain't easy if we don't know what cooler it is and where it's going??????? If it don't make a difference neither does it make a difference what wire you cut.
Old Mar 6, 2017 | 03:05 PM
56Jimmy's Avatar
56Jimmy
Sorry not enuff info. I need to to know if it makes any difference which fluid line I cut into. The steel OEM lines going from trans to factory cooler
Old Mar 6, 2017 | 08:49 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
On a 2005 6.0L I suspect that an additional cooler is going to increase cooler line restriction, which will reduce cooling capacity.
How hot is it getting without this cooler?
Old Mar 10, 2017 | 09:07 PM
BII Plow Truck's Avatar
BII Plow Truck
A trans cooler should be after the factory built-in cooler in the radiator.
Hot fluid goes out the transmission, through the built-in cooler, out to the auxiliary cooler, and back to the transmission. You need to find out which line is supply, and which line is the return. Google is your friend.
Old Mar 11, 2017 | 05:36 PM
69cj's Avatar
69cj
I'd advise you listen to Mark when it comes to the torque shift tranny. It'll save you some money and heartache. Just sayin!
Old Mar 11, 2017 | 07:59 PM
mrgrayaz's Avatar
mrgrayaz
We regularly tow heavy with our 05 6.0. - 16k GVWR 5th wheel.
Transmission cooling is simply not an issue in this truck.
Old Mar 12, 2017 | 11:01 PM
P.Bronner's Avatar
P.Bronner
You're pulling a trailer that weighs 15,000 empty - and considering a boat behind that - with a 250. The first thing you need is a bigger truck.
Old Mar 12, 2017 | 11:42 PM
Thor'sHammer's Avatar
Thor'sHammer
Return it. The 5R110 has the best cooling of basically ANY automatic transmission. The cooling system for the transmission behind a 6.0L is actually used as an UPGRADE to most other trucks.
SoCalAngler
Aug 13, 2020 10:52 PM
timmyboy76
Dec 30, 2017 06:19 PM
enriched&beyound
Feb 7, 2017 07:36 AM
hosoria
Aug 12, 2010 06:04 PM
69_bronco
1966 - 1977 Early Broncos
Jun 9, 2004 12:49 AM
