Hi,I bought a 25$ reproduction for the pass. battery cut all the spot welds and flipped all of the brackets on the tray to the opposite direction and welded it back together and made a factory drivers side tray that looks stock and bolts in to all of the factory locations.The trays are mirrors of each other..
Chris
Chris
That's not possible if the brackets are physically mirrored of each other.
That means the brackets would have to be bent 180° or the brackets are not bolted to the core support and inner fender as originally designed.
If it is, then kudos. But I've thought of doing the same with a passenger bracket and its a no-go.
Dang it, you are correct. Just put my aux tray beside a passenger-side tray and the bolt holes would need to swing 180 to fit. Crap.
Back to the hunt!
Thx for pointing that out.
Back to the hunt!
All is not lost...an option is to find a rotted driver-side tray and drill out its brackets and reuse them on the repro passenger-side tray... after removing its passenger-side specific brackets of course.
That's exactly what I ended up doing. Used my old driver side brackets on a new passenger side tray bottom (after removing its brackets).
Good as factory new!
