Contour Bumper Brackets?
Old May 3, 2018 | 07:11 AM
1STFOX's Avatar
1STFOX
Just scored a nice contour bumper for my '78 SWB. I have searched the forums and read that there are no bumper
brackets available for the 73-78. I have seen posts on making brackets and that Bronco brackets will not work either...
My question is, has anyone used the '72 brackets (C4TZ-17787) available from Dennis Carpenter or LMC? I know they will not bolt in,
but it might be a start... Thoughts??
Old May 3, 2018 | 07:37 AM
hivoltj's Avatar
hivoltj
The bronco brackets will work if u extend them. Hiosilver had a post on it, I did as well
Old May 3, 2018 | 09:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 1STFOX
Just scored a nice contour bumper for my '78 SWB. I have searched the forums and read that there are no bumper brackets available for the 73-79.
My question is, has anyone used the 1964/72 brackets* (C4TZ-17787 ) available from Dennis Carpenter or LMC?
1964/72 brackets will not work on 1973/79's.
D3TZ-17787-C Right Inner / D3TZ-17788-C Left Inner / D3TZ-17795-B Right Outer / D3TZ-17796-A Left Outer .. 1973/79 F100/350 Styleside Contour Bumper Brackets / Obsolete
Note: F350's on the 140" wheelbase use different inner brackets. The outer brackets are the same.
C4TZ-17787-A Right Inner / C4TZ-17788-A Left Inner / C4TZ-17795-A Right Outer / C4TZ-17796-A Left Outer .. Styleside Contour Rear Bumper Brackets / Reproduced
*1964/66 F100/250 2WD; 1966 F100 4WD; 1967/72 F100/250 2WD/4WD & F350.
Note: 1964/65 F100/250 4WD; 1965/66 F350; 1966 F250 4WD use different Stylesides beds, contour bumpers and brackets.
Old May 3, 2018 | 01:23 PM
monkey-1's Avatar
monkey-1
I just made some of these for my dads '85. Not too difficult to build, just a little time consuming. We wanted them to fit up close to the truck and be stout. All out of 1/4 and 3/8 inch material from the scrap bin:
After these get mounted, there is a gap between the bumper and the truck bed. We took a piece of plastic trim off the side of the donor car (crown vic) and trimmed it to make a piece that hides this gap:
Old May 3, 2018 | 05:18 PM
1STFOX's Avatar
1STFOX
I saw your post and took some pics to use as a reference... Dennis Carpenter has the early model brackets and just thought it
might be easier to start with them...
Old May 3, 2018 | 05:22 PM
HIO Silver's Avatar
HIO Silver
The Bumpside inner brackets will work... the outer "wing" brackets will need to be modified because the relative position of the holes (frame vs bumper) are different.
Old May 3, 2018 | 07:15 PM
1STFOX's Avatar
1STFOX
Done deal! ill order the brackets and make the outer brackets... Thanks HiO Silver!
benbuilder
17
Aug 24, 2024 02:24 PM
columbia1spring
Apr 26, 2020 01:00 PM
MichaelJB62
Sep 20, 2016 08:26 PM
77FordExp
Apr 13, 2016 08:58 PM
Troubleuk
WTB - Parts & other
Aug 1, 2015 03:04 AM
