Does this sound ok?
Old Mar 6, 2017 | 09:28 PM
Don Naslund's Avatar
Don Naslund
Sounded good to me.
Old Mar 6, 2017 | 11:23 PM
Watcher58's Avatar
Watcher58
Got the AE scanner activated for the 2nd time. Only code was PO675--cylinder 5 glow plug circuit
I have new glow plugs and harrnesses which I was going to install...guess sooner than lateer.
Did the jump start everything was even and smooth on the turnover
so....would that be an indication I can sleep well at night?
Old Mar 7, 2017 | 12:08 AM
Yama4fitty's Avatar
Yama4fitty
That is definitely great news that you do not have a base motor issue
The glow plugs can have circuit issues with the plugs at the GPCM not being seated properly, the plugs at the buss bars not being seated properly, wires being kinked, or the glow plugs being simply faulty.
Since you are replacing everything just make sure the plugs seat and click into the GPCM completely. Maybe take a look at the prongs to be sure they are straight.
Old Mar 8, 2017 | 09:58 AM
Sarge261's Avatar
Sarge261
Like I said I don't here anything in the last video that would be alarming to me. Any diesel that has any type of engine know will be unmistakable...trust me.
Sleep tight, don't let the bed bugs bite!!!
Sarge
Old Mar 8, 2017 | 10:02 AM
WatsonR's Avatar
WatsonR
By using the jumper wire on the passenger side... that allows it to just crank without starting... it gives you the opportunity to just listen to it. Nice even cranking... sleep good!
speakerfritz
6.4L Power Stroke Diesel
Jan 11, 2016 11:00 AM
Tepot
19
Apr 16, 2015 02:09 PM
1bad04
May 10, 2011 10:01 PM
ARHMogul
1997 - 2003 F150
Nov 15, 2010 04:55 PM
ArmyRanger
1983 - 2012 Ranger & B-Series
Jun 22, 2004 12:59 PM
