Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Building an Axle?
Old Mar 3, 2017 | 08:46 PM
NoFrod's Avatar
NoFrod
Building an Axle?
I'm looking at a salvage axle from a F700 with Lucas Girling brakes to replace in an older F-850 with straight juice brakes. Can the hydraulic service brakes on the Lucas-Girling setup be used as straight hydraulic brakes ? Or, am I best off replacing the backing plates and abandoning the Lucas-Girling (much more cost) ? The parking brake for that F-850 is on the driveline and is independent of the service brakes. I understand that I would need to permanently release the Lucas-Girling parking brakes somehow. Advice welcome.
Old Mar 3, 2017 | 09:20 PM
Tenwheeler's Avatar
Tenwheeler
If you tighten the caging bolt in the center of the parking unit it would work fine. Would a DOT guy have a problem with that? Just cut the end of the bolt off after you cage them and plug the lines?
I never did that one but different brake systems do not normally bolt up on different axes.
Old Mar 4, 2017 | 02:47 PM
NoFrod's Avatar
NoFrod
Thanks. I take the latter part of your response to mean that I wouldn't have the option of replacing the backing plates for conversion to a straight juice brake setup. That will be fine, I suppose.
Old Mar 4, 2017 | 07:22 PM
Tenwheeler's Avatar
Tenwheeler
I have put S=cam brakes in place of wedge and old air disc brakes. Both required custom fab work and I would expect the same with what you are doing. Don't know tell you get there unless someone that has done it replies.
BigBlockF350
56
Apr 2, 2013 05:55 PM
mrblonde108
Large Truck
48
Aug 24, 2010 11:44 PM
68bluebeast
Aug 5, 2008 12:56 PM
magusjinx
Feb 15, 2008 09:25 PM
Titantis
Jun 4, 2007 02:14 PM
