Sponsored by: Kumho
brakes
Old Feb 4, 2008 | 12:06 PM
magusjinx's Avatar
magusjinx
brakes
I know about drum and disc brakes (sorta) ... I have seen exhaust brakes and know about how and why they work ... I am now interested in driveline brakes ... What would be the dis/advantages about them?
Old Feb 4, 2008 | 11:07 PM
gnwalker's Avatar
gnwalker
You mean a pinion brake? A disadvantage would behaving only one rotor per axle thats gona hafta work twice as hard to stop and cool down. I would think trying to lock up your tires to come to a sudden stop if you had to could be very hard on gears and axle shafts if its even possible. I cant think of anything that would be real advantagious in the long run
Old Feb 5, 2008 | 04:32 PM
magusjinx's Avatar
magusjinx
Not pinion ... I once saw a disc brake setup on a driveline ... At least that is what it looked like ... perhaps these are more on bigger rigs rather than our everyday drivers ...
Old Feb 5, 2008 | 06:04 PM
rebocardo's Avatar
rebocardo
They are for parking and usually you only see them on medium weight trucks (14,400-25,900) that do not have air brakes.
Old Feb 5, 2008 | 06:59 PM
gnwalker's Avatar
gnwalker
check highangledriveline.com
Old Feb 5, 2008 | 08:13 PM
magusjinx's Avatar
magusjinx
Tanx for the link ... Since it look sto be after the transfer case it would hold the tires of even an AT in neutral ...
I needed a bib for the 3-speed transfer cases ...
Old Feb 15, 2008 | 09:25 PM
tomcasino's Avatar
tomcasino
Another disadvantage would be a broken u-joint. Then no brakes. I've seen driveline calipers for e-brakes. And mud trucks use them to keep the brakes up higher out of the mud.
