over-inflate to increase speed rating
Received 6,718 Likes
on
No, this is incorrect. You always set tire pressure at their cold temp PSI. As Misky6.0 said, tires will go beyond that PSI when hot and that is normal. I had an email conversation with BFG techs a few years ago regarding my "P" metric tires and how to set them when towing. In the case of those tires, they had one pressure setting and BFG said you always set it that way (cold) no matter what. LT tires are only slightly different in that they can be set at a range but never to exceed the max PSI when cold.
The PDF, from Goodyear, NEVER says exceed the max pressure on the TIRE, it says over the TRAILER's placard PSI recommendation.
Thus, like on the driver door jamb, the trailer placard may say recommended tire pressure 45 lbs. But, we all (?) know too use max pressure OF THE TIRE for max capacity.
on
So if you are using a LRC and your placard says to inflate to 50psi, then you are stuck to a 65mph speed limit.
This leaves one to think that going from a LRC to a LRD *should* let you increase your speed rating if you inflate to the max for a LRD.
But, re reading the memo, it does say to stick to the max cold inflation listed.on the tire.
john112deere
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
04-16-2007 08:55 PM
Templer
03-31-2004 11:06 AM
