Modular V10 (6.8l)
Tire Pressure
Old Mar 2, 2007 | 11:43 AM
Kennicol's Avatar
Kennicol
Tire Pressure
I have 265x75 16 tires. What would be a good pressure to keep them at I have been told several different psi. Right now I have the rear at 50psi.most of the times the bed is empty I don't haul very heavy loads when I do haul anything. Pull a 25 ft travel trailer camping several times a year.
Old Mar 2, 2007 | 11:54 AM
lswartz's Avatar
lswartz
Mine are 245/75/16 and 80lbs. max on a van. I run it at 50lbs. too. I get even tire wear on the back & pull a 30 ft. travel trailer. When I put 2 new tires on the rear last month they filled them up to 80lbs. & it bounced around all the way home. 50lbs. seems to soften it out a bit.
Old Mar 2, 2007 | 01:37 PM
wfof250v10's Avatar
wfof250v10
I've got the 265X75 R16's. They say 80 psi max and I keep mine at 70 psi front and back. I keep them at that psi for towing the 9,200 lb 5th and empty. The tires have worn even after 23K miles on them (BF Goodrich) I've had them at the recommennded pressure located on the inside door jam and the seemed a little mushie in the front end at 55psi when towing.
Cdashner
6.7L Power Stroke Diesel
Nov 3, 2014 08:50 PM
nomorecummins
6.4L Power Stroke Diesel
Sep 17, 2010 01:32 AM
mizzitch
Aug 28, 2010 10:00 AM
xjcamaro89
2004 - 2008 F150
Aug 16, 2010 08:04 AM
OC2SNOW
Nov 24, 2004 10:30 PM
