NEED TO INSTALL NEW FIPL SWITCH
Old Mar 3, 2017 | 09:23 AM
dutyhole's Avatar
dutyhole
I HAVE 1994 E 350 7.3 NON TURBO SHE REALLY SHIFFTING BAD IN AND OUT OF GEAR AFTER 35 MPH HAVE A 23 CODE AND THE O/D LIGHT COMES ON ALOT ALREADY DID THE DIFF SENSOR AND THE NEAUTRAL SWITCH SO WHAT IS THE CORRECT WAY TO DO THE NEW FIPL SWITCH THE VAN RUNS GREAT AND I DO TAKE CARE OF IT AND DO WANT TO BLOW THE TRANNY ALLREADY DID THAT TOO WITH A NEW CONVERTER ANY HELP WOULD BE GREAT !!
Old Mar 3, 2017 | 10:37 AM
Jarkill's Avatar
Jarkill
Have you checked the connections on the trans harness? They are known to deteriorate and reek havoc on trans performance. It is completely fixable and is usually the cause of most of these codes. There is a thread on here about it called "The importance of a clean trans harness"
Old Mar 3, 2017 | 12:05 PM
dutyhole's Avatar
dutyhole
YES I EVEN WENT BOUGHT ELECTRICAL SPRAY AND DIE ELECTRIC GREASE AND CLEANED ALL SENSORS AND GREASED
Old Mar 3, 2017 | 12:12 PM
Jarkill's Avatar
Jarkill
https://www.ford-trucks.com/forums/1...ions-only.html
This should help
Old Mar 3, 2017 | 12:32 PM
Scott in TX's Avatar
Scott in TX
Did you have the pedal depressed to the floor during the test? if you don't that will show as a code 23
Old Mar 3, 2017 | 01:09 PM
dutyhole's Avatar
dutyhole
YES WE DID TY
f100guy
Nov 23, 2009 12:12 PM
BIIhdridr
Bronco II
Nov 18, 2006 01:49 PM
mhannink
Dec 1, 2005 08:02 PM
drunkcaballo
1983 - 2012 Ranger & B-Series
May 24, 2004 10:39 AM
