car polisher
Old Mar 2, 2017 | 09:32 PM
car polisher's Avatar
car polisher
car polisher
I have a 54 F100 239Y block 3 spd. on the column. I am putting in a 351w out of a 85 F250 with c6 trans. I am trying to figure out my gear ratio on my 54. On axle it has 47/12 on gear ratio tag and the following numbers on the passenger's side of axle- 64B 4' 2169. Can some help me with this? I'm thinking I might need a 3:51 gear set up?
Additionally I am selling my 239 Y block, it runs but smokes. I have video of it running in truck.
Old Mar 2, 2017 | 09:53 PM
BlueOvalRage's Avatar
BlueOvalRage
The 47/12 tag refers to the ring and pinion gear tooth counts - 47 teeth on the ring gear and 12 on the pinion. This means you have the original 3.92:1 ratio. That ratio is a little low for a modern engine with a straight 1:1 final drive ratio in the transmission like the C6, but it would be just about right with a transmission that has an overdrive gear. If you're positive that you want to keep the C6, you'll probably want to look at running something between a 3.00:1 and a 3.55:1 depending on your driving style and planned use for the truck.
52' fordnut
Oct 1, 2012 08:42 PM
rocdril
Oct 9, 2008 06:54 AM
1987 f250
May 9, 2004 09:01 PM
kkoles2000
May 8, 2004 01:20 AM
swamper
Offroad & 4x4
Jun 8, 2001 08:52 PM
