Instrument Cluster Help
I went out to drive my 72' F100 last night and when I turned on my lights i noticed the temp gauge and oil pressure gauge bulbs were burnt out. I am away at college and don't have access to tools to pull the bulbs but I am going home for spring break in about 2 weeks. Does anyone know where I can buy a new set of bulbs? (either online or in stores, I kinda wanted to see if i could replace them with LED bulbs) I would rather order them online and have them waiting for me at home rather than trying to struggle to find them if they are no available in stores. Also, is there any special way to take out the instrument cluster? This will be my first time doing this I am sure it isn't too difficult.
Thanks for all the help!
Here say that the Led's when used in dash lights is a fixed brightest that is not adjustable with the head light switch to dim if to bright!
Do some research before buying them.
Orich
Cutequeen 10PCS LED Car Lights Bulb White T10 2835 4-SMD 80 Lumens 194 168 (pack of 10) May have to cut and paste
They are a nice clear white light, not too overpowering, but cannot be dimmed.I can finally see my speedo and gauges at night.
I have done the alternator upgrade, not sure if you have, or if it would make a difference.
For the instrument cluster, there are just 8 or 10 phillips screws around the outside of the bezel, pretty easy to remove.
If you use the LED's I posted, and perhaps any LED, if at first they do not work, try removing the socket from the cluster and turning it 180 degrees and reinsert, then it should work, if everything else is working fine.
Hope this helps.
But now noticed after adding one of the electronic flashers that my cruise control has now stopped working. So put back the oem flasher an put up with the faster blinking.
I still get some voltage bleed over when using the blinkers until, I turn on the head lights that correct the bleed over problem.
What a pain in the azz to run Led's, I did not install any in the dash as, I do like to set the brightness of the dash lights.
Orich
Scott Drake Instrument Panel LED Bulb White Set 1965-1968
- http://www.facebook.com/sharer/sharer.php?u=http://www.cjponyparts.com/scott-drake-instrument-panel-led-bulb-white-set-1965-1968/p/SD1895/
More Parts from Scott DrakeProduct Description
Set of Four Scott Drake Instrument Panel White LED Bulbs for all 1965, 1966, 1967 1968 Mustangs.
Scott Drake's LED bulbs are four times brighter than factory incandescent bulbs, so your pony’s dash will be brighter than ever once you install this Instrument Panel Bulb Set! LEDs also much cooler than incandescent bulbs, so their overall lifespan is much longer than your Mustang’s original factory bulbs. You won’t be in and out of the dash every few months replacing bunt-out bulbs—instead you’ll be cruising down the road without a care!
This Instrument Panel Bulb Set includes four direct-fit replacement bulbs in your choice of either white or blue. They will easily install into standard 1895 sockets and can either replace your original factory bulbs or replace any upgraded bulbs that have burnt out over the years.
Please Note: These bulbs are available in two different colors, blue or white. Please indicate your choice of bulb color in the drop-down menu.
Scott Drake has become an iconic brand that redefines quality for reproduction and aftermarket Mustang parts for 1965 to present Mustangs, and has become the standard for OEM quality Mustang parts that offer the best fit, durability and quality. Every part is designed to look and function exactly like the original, right down to the tiny details that the manufacturers of standard reproductions tend to ignore. CJ Pony Parts is proud to offer a huge selection of restoration-quality parts from Scott Drake for your classic beauty. Browse around and pick something up for your Mustang today!
Order a Set of Scott Drake Instrument Panel LED bulbs for your 1965, 1966, 1967 or 1968 Mustang from CJ Pony Parts today!
1895 bulb has 2 candlepower and could be subbed for 53 and 1445.
