E4OD Planetary Gears. Upgrade?
Old Feb 28, 2017 | 09:45 PM
8285's Avatar
8285
Hi guys, I'm back with another question.
Upon disassembling my transmission, I discovered that all my planetary gears are the 3 pinion design. I'm trying to decide whether or not to upgrade them. And if I do upgrade them, what to upgrade to.
My engine is the 4.9, all stock. No performance upgrades and I'm not planning any. I'll be doing some light towing (6X12 enclosed trailer) and I might upgrade to a slightly bigger trailer in the future. I won't be doing any off-roading or racing, but I won't baby the truck either. Simply speaking, I want a trans that can take all a stock 4.9 will give it.
I have seen replacement planetary gears in two styles, 4 and 6 pinion. They come in aluminum or steel. Question is, which ones to get. I was thinking 6 pinion aluminum for the forward planet, 4 pinion aluminum for the overdrive planet and 4 pinion steel for the reverse planet. But I really don't know which ones I need, which is why I came here for help.
Any input you can give is much appreciated.
Thanks!
Old Mar 1, 2017 | 05:53 AM
Briansshop's Avatar
Briansshop
IMO,no need to upgrade.
Old Mar 1, 2017 | 10:17 AM
Dutter 2's Avatar
Dutter 2
Beings that you have a stock 4.9 and light towing just use factory planets and if you want to upgrade something upgrade your valve body. That'll do you the most good out of any mod. Coming from a guy with a e4od on a chipped powerstroke pulling horses on 35 inch tires
Old Mar 1, 2017 | 09:37 PM
8285's Avatar
8285
Thanks for the advice! My main concern with the original planets is that they have nearly 200K miles on them, some of those miles with low fluid. At the same time, I'd like to save the extra $ and not replace them...
This is a hard decision! But your advice is definitely helpful. Before this thread I was 90% sure I needed to upgrade them. Now I'm seriously considering reusing them.
I have a great idea, I'll go to bed and maybe there will be more advice here in the morning!
Old Mar 1, 2017 | 09:46 PM
DieselCamper's Avatar
DieselCamper
On parts like that, I say if it ain't broke, don't fix em.
Old Mar 1, 2017 | 09:47 PM
Dutter 2's Avatar
Dutter 2
Yep x2. Just do a good visual for wear and movement
Old Mar 1, 2017 | 09:48 PM
Dutter 2's Avatar
Dutter 2
When planets wear they get sharp edges
Old Mar 2, 2017 | 06:21 AM
8285's Avatar
8285
Just to clarify, are you doing this with the factory 3 pinion planets? If so, they're stronger than I thought.
I will inspect them for sharp edges and post some pictures of what I find.
Thanks!
Old Mar 2, 2017 | 07:20 PM
Dutter 2's Avatar
Dutter 2
Thanks!
hmmm u know I can't recall. Iv rebuilt a few e4od and remember the diesel ones having better thrust bearings but idk about more planets I don't think so. The tranny I have now has been rebuilt and modified by some company. It's got billet tq converter shift kit and more clutches on the OD
Old Mar 9, 2017 | 07:09 AM
8285's Avatar
8285
The edges on the current planets look fine to me based on pictures of new planets.
I'm more concerned about the splines stripping out on the OD and forward planets than I am about the planet housings cracking. I don't want to floor the truck to get on the expressway and have it strip the OD or forward splines. But a drivetrain is only as strong as its weakest part, so I probably need to be worrying about something else than planetaries.
Old Mar 14, 2017 | 09:16 AM
8285's Avatar
8285
For anyone reading this thread, I couldn't resist upgrading the planetaries since I already had the transmission apart. I ended up purchasing the steel 6 pinion forward planet, the steel 4 pinion OD planet, and the aluminum 4 pinion reverse planet. I wanted steel for the forward and OD so that the splines would not strip out. The reverse planet doesn't get as much wear and tear, so I couldn't justify the expense of a steel 6 pinion planet for it.
Does anyone know why the pinion thrust washers have cracks in them at the base of the tabs?? My original ones were cracked so I was going to replace them, but it looks like new ones are cracked as well.
Are these cracks normal??
Old Mar 14, 2017 | 05:30 PM
My4Fordtrucks's Avatar
My4Fordtrucks
For lubrication. It is not a 'crack'.
Old Mar 14, 2017 | 06:48 PM
Briansshop's Avatar
Briansshop
Cracks are normal. Happens when they are bent over/being made.
Rescue1950
Mar 19, 2010 09:14 PM
gmm
Feb 10, 2009 04:59 PM
LilDuke
Dec 29, 2004 12:01 PM
pcman
Dec 23, 2001 08:34 PM
