Towing
Old Feb 28, 2017 | 07:58 PM
pyasher's Avatar
pyasher
7th Gear
Towing
Ok about to purchase a real truck ( 2006 F150 with 5.4) currently have a 2001 S10 we purchased new. (Wife would not drive 1/2 ton) My question is about towing. What is included in the towing package on a 2006? How can you tell if the truck has the towing package? If not will it make a good tow vehicle (enclosed car trailer 20 X 8.5) . I know it is a very basic question so thanks for the help and be kind please...
Old Mar 1, 2017 | 07:49 PM
steve(ill)'s Avatar
steve(ill)
that trailer weights over 3000 # and a car could weigh 4500# , so your about 7500# of weight ( about)........ the 5.4 is good, but you want to check the axle ratio of the truck. I have a 3.55 and it works good. I would not get less than that. 3.7 would also be a good choice. you can get the axle code off the door jab. .......... I don't know the specifics, but a factory tow package would include a BIG electrical plug on the back bumper, not the smaller 4 pin.
Old Mar 2, 2017 | 12:13 AM
46fordtruck's Avatar
46fordtruck
The tow package would have the 7 pin connector as previously mentioned, a frame mounted hitch, auxillary trans cooler and upgraded radiator. My '07 is equipped with the factory tow package and has all of these. The trans cooler is mounted in front of the radiator towards the bottom when you open the hood.
Old Mar 2, 2017 | 01:12 AM
Bluegrass 7's Avatar
Bluegrass 7
You have not offered enough info about the truck build.
Look in your owner manual pages 187 to 197.
Find your specific build and look at the GCWR figure.
Subtract your loaded truck weight from GCWR and that is the max you can legally tow.
After this it's matter of aux trans cooling, trailer hitch equipment, mirror extensions both sides and Trailer brake controller in the Cab, rated tires should be LT type.
Good luck.
SJMaye
2015 - 2020 F150
18
Mar 2, 2018 08:24 AM
dvlsmstr
Escape & Escape Hybrid
Aug 1, 2014 11:26 AM
96blackford
Sep 3, 2013 11:54 AM
AkanaF150
1997 - 2003 F150
Sep 26, 2010 03:20 PM
ampegor
2004 - 2008 F150
Aug 17, 2007 10:03 PM
