Dana 60 front axle sway bar
I'm looking to put a front axle sway bar on my 1974 f350 . It has a dana 60 hp in it from a '78, and I was wondering if any of u guys might have a part number of one you have used or even a couple of pictures of your sway bar setup. Any info is appreciated, thanks.
on
If you found one at a junk yard, it could be installed in the factory location fairly easily.
If you have a look through my build thread (link in signature), you'll come across the rear sway bar that I cleaned up and installed new bushings for.
The front sway bar looks the exact same, but it's 1-1/8" (front) diameter instead of 1" diameter (rear).
Mounts the same, all the same pieces, just the thickness is different (which changes which bushings you buy).
I'm not sure where to locate the # for the front sway bar, but I'm betting the master parts catalog has it listed. I'll have a look and get back to you in a moment.
EDIT:
So I don't have any photos in my build of my front stabilizer bar, but I did find the Master Parts Catalog diagram of it. I'm not 100% certain, but I believe my sway bar doesn't have the odd connection directly above the pinion as the diagram shows... but again, I'm not 100%. IIRC, my memory tells me that the front sway bar mounts almost identically the same way the rear sway bar does on my truck.
on
I also did a quick Google Search and came up with a really great post by NumberDummy.
Here's the original thread:
https://www.ford-trucks.com/forums/5...sway-bars.html
Here's the Quote from ND:
Ford offered two front 4X4 stabilizer (sway) bars, and one rear 4X4 stabilizer (sway) bar for 1977/79 F Series Trucks.
Front Stabilizer Bar
D7TZ-5482-A Stabilizer Bar .. Fits: '77/79 F250 4X4; '78/79 F150 Super Cab 4X4; and '79 F350 4X4.
D8TZ-5482-A Stabilizer Bar .. Fits: '77/79 F150 Regular Cab 4X4
Rear Stabilizer Bar
D7TZ-5A772-A Stabilizer Bar, Rear .. Fits: 77/79 F250 & 79 F350 4X4
NOTE: None of the above part numbers cross over to 1980/89. The 1980/89's use different bars.
Sources: 1973/79 & 1980/89 Ford Light Truck Parts catalogs.
Rear Stabilizer Bar
F350's were not available with factory installed 4WD until 1979. So if your F350 has 4WD, it's a conversion, possibly performed by Marmon-Herrington.
No front sway bar was factory installed with 4WD until 1977.
D7TZ-5482-A .. Front Sway Bar / Obsolete
1977/79 F250 4WD; 1978/79 F150 Super Cab 4WD; 1979 F350 4WD
Sycostang67
09-09-2010 08:05 PM
Blackfoot Big Block
12-28-2009 09:25 AM
