Injector cup removal
Old Mar 16, 2017 | 09:15 AM
  #61
andym's Avatar
andym
Originally Posted by jhl3
Not a dumb question at all.
I torque the upper bolt first, post seating, because the injector clamp slides over it and then slides downward thus locking the injector in place using the upper bolt as a reference and guide. I also used the above referenced Loctite to help keep it torqued to spec because I learned that the uppers were causing the loose injectors in this truck. Then the lower bolt is installed and torqued to spec which completes the see-saw that Rich refers to. The shoulder on the injector acts as a resting point for the "fulcrum" of the injector clamp "see-saw". If you look at the clamp, there is a slight hump.
Ok, that makes sense. Thank you.
Now, I have a question. Which/whose tool did you use that allowed you to leave the upper bolt in place while replacing cups?
Nicmike was gracious enough to get let borrow his. The puller tool was round and just fit into the bore. It wasn't one of the big rectangular heads that need lots of space.
RLICHT
23
Dec 8, 2013 08:22 PM
wycowboy
Apr 6, 2013 09:16 AM
OldWoodsDiesel
26
Oct 19, 2012 06:56 AM
Brett W 55 Ford
Nov 20, 2010 11:08 PM
Vankaye
Feb 14, 2010 09:11 PM
