No the fluid in the bottom is brake parts cleaner. It's been brushed out and sprayed multiple times. There's a ring of discoloration around the opening. I don't know how it could be sealant. It looks bonded to the metal.
You can ignore that, the bore is clean - which is the critical part. That ring looks like nothing more than an indentation from pressure from the injector copper washer. Maybe this was a loose injector, and you were getting some hammer in there. The cup and retaining compound will smooth that over, and it won't come into play.
Ok, that's a relief. I thought I did have a slightly noisy injector, but it sounded to me like it was on the other side. As long as I'm done cleaning that bore out. What a PITA it is to get done on #5 and #7.
Speaking of PITAs... the seal driver tool keeps getting stuck in the cups after installation. It's currently stuck in #1 without any sign of loosening no matter how hard I pull on it. They started getting progressively tighter. The last one I did was #8 and it was stuck in there good. I found that a shot of PB helped free it, but I don't know about the effects of PB blaster on still-curing loctite 620 so I just left the tool in there overnight this time. I tried dabbing the end of the tool with fresh motor oil before I drove this last one in, but apparently it didn't help. In addition to not being able to get the tool out easily, I'm also worried that it might damage the cups on the way out.
I wish the end of the installer was threaded, but it's not. Any ideas on how to un-stick it?
I always goop the tool with silicone lube before using it to install a cup. A word of caution - make sure the cup has none of that on the mating surface to the engine. I never had an issue with extracting the tool from the cup.
Gently tap the sides of the install tool until it comes free. You could also twist it. Then use Rich's advice to keep it from sticking on the rest of them.
I got all 8 cups installed, and the pressure test passed. It held pressure for at least 15 minutes and I sprayed silicone in all the bores and didn't see any bubbling or signs of leakage at all.
As for holding air, the real test is 24 hours. The silicone spray test circumvents waiting 24 hours and is far more reliable. Congratulations! Well done!
Andy, I will assume that you have removed both the top and bottom hold down bolts for cup removal so what follows is on point.
In early December '16 I replaced injectors. When checking the torque values on the lower hold down bolts they were all within spec at 120 in/lbs. However, when I checked the upper hold bolts some were as low as 55 in/lbs which explains the loud engine due to loose injectors. There is a ton of speculation as to why they had worked loose and I won't spend any time on the possibilities for their looseness.
I also used the primer: Loctite 19269 7649 Primer N Activator after cleaning and drying all holes of oil and dirt. I then applied Loctite 243, installed and torqued the upper hold down bolts and let them cure for 24 hours.
Injectors were then seated. Then, the lower hold down bolts were torqued to 120 in/lbs initially and then HOT torqued.
I now have a quiet, it is relative, running 7.3L. I did exceed the factory spec on torque by 15 in/lbs on both.
I now think that I am preventing damage to cups thus preventing a future repair job.
My injectors are due to arrive today and I'm pretty sure I won't be able to resist starting to install them. When I removed them, I took out the lower bolt but left the upper one in place. Reading your instructions it says to torque the uppers, seat the injectors, then torque the lowers.
My question is probably a dumb one, how do you torque the upper before the injector is even seated in the bore?
It rained today, so no injector work. I did get the FRx lines on the heads and installed the HPOP and lines before it rained. Those lines click on really easy. They don't seem like they're on all the way but they don't pull off either. I guess I will find out when I crank it the first time.
Will post a picture in a second. I haven't even unpacked them all yet. Yes they are from unlimited.
I had the same thought about the HPOP lines when I changed mine out a couple of months ago. I thought, well that is not going to work. Then pulled on them even using leverage from a screwdriver on them and they were not budging. They held well and are doing great.
The injectors are very nice looking. Congrats on the work you have done and the work you have yet to do.
...My question is probably a dumb one, how do you torque the upper before the injector is even seated in the bore?
The top bolt is a shoulder bolt, it seats on its own. The bottom bolt holds the injector down like a see-saw, not flat like one would suspect. The bottom bolt never seats, it just puts the correct amount of pressure on the injector hold-down see-saw. The other side (anchor side) of the see-saw is the top shoulder bolt.
Not a dumb question at all.
I torque the upper bolt first, post seating, because the injector clamp slides over it and then slides downward thus locking the injector in place using the upper bolt as a reference and guide. I also used the above referenced Loctite to help keep it torqued to spec because I learned that the uppers were causing the loose injectors in this truck. Then the lower bolt is installed and torqued to spec which completes the see-saw that Rich refers to. The shoulder on the injector acts as a resting point for the "fulcrum" of the injector clamp "see-saw". If you look at the clamp, there is a slight hump.
Now, I have a question. Which/whose tool did you use that allowed you to leave the upper bolt in place while replacing cups?
