Sponsored by: Real Truck
Key in ignition warning ground switch
Old Feb 26, 2017 | 08:57 PM
EnemyOfReality's Avatar
EnemyOfReality
Hi all! It seems like this is somewhat of a common problem. The key in ignition ground connector on my 2003 F250 broke. I know some of you have either used epoxy to fix it or just just a ziptie to keep it in place. My question is does anyone know what that connector's part number is, or is even called? I can find the connector that's attached to the ignition switch itself but I don't need that part, I just need the part that clips onto where the switch sits. If it's not an easy part to come by, or is even still sold, then I'll try the ziptie method. Any help is appreciated. Thanks!
Old Feb 27, 2017 | 04:47 AM
seville009's Avatar
seville009
Don't really have an answer, but maybe you could grab one at a salvage yard.
Old Feb 28, 2017 | 01:06 PM
EnemyOfReality
That could work I guess if I can find a yard around my area that has any of these trucks.
bigblockford_390
Nov 4, 2011 11:26 PM
brknight
Jan 2, 2011 09:13 PM
mark8881
1997 - 2003 F150
Oct 19, 2008 02:10 PM
fitzg2md
Jan 24, 2007 03:03 PM
orangedbowl
May 10, 2005 11:09 PM
