Mirror fell off...
Old Feb 28, 2017 | 02:57 PM
F250_Super_4X4's Avatar
F250_Super_4X4
Hey look... a chupacabra?
Old Mar 29, 2017 | 10:25 AM
PapaBearYuma's Avatar
PapaBearYuma
mirror update
The mirror fell off again, so I used a flat file to take the smooth surface off the button. I was in the hardware store, and saw "KrazyGlue", and figured I'd give it a shot.
I applied a drop of KrazyGlue, held the button in place for a couple minutes, then let go. It stayed. I let the button cure overnight, and it was still attached the next day. I hung the mirror on the button, and it didn't fall off. I left it overnight, and it was still there the next morning.
I drove the truck that day, and had to adjust the mirror. Very carefully, while holding the button with one hand, and manipulating the mirror in the other hand, I adjusted the mirror. When I was done, the entire assembly fell onto the dash.
Another week went by, and I took the truck to John's Glass on my lunch break. They replace auto windshields, so I asked them to re-attach the button. The technician had a yellow box labeled Loctite 12 and a green spray can (activator?) He marked the windshield from the outside, and two minutes later, he was done. Seems secure. We'll see...
Old Mar 29, 2017 | 10:32 AM
good to doo's Avatar
good to doo
Something so simple it seems, becomes a major pain. Hope that ends it.
Old Mar 29, 2017 | 10:39 AM
EQCMCAT's Avatar
EQCMCAT
Had the same problem W/my 95 F-150 Eddie Bauer. Liking the smaller mirror in my 92 Ranger, I got another and installed it in the 95 F-150 Eddie Bauer using the Permatex mirror adhesive along W/proper prep. Hasn't come off since 2009. The smaller Ford OEM mirror looks better in my opinion and is easier getting a small / short rosary or Indian Arrow Head or whatever over the smaller mirror.
Old Mar 29, 2017 | 10:45 AM
Dasher400's Avatar
Dasher400
I JB welded the one on my '78 when I replaced the windshield. Gravel roads, hunting, and drift busting for 5 years and it never budged. Good stuff!
Old Mar 29, 2017 | 12:18 PM
lasermike's Avatar
lasermike
Hopefully ninth time is the charm!
Mine's still sticking with the IC-2000 but it hasn't been through a summer yet. How much did they charge?
Michael
PS, the green can is activator. Cyanoacrylate glues cure in the absence of oxygen. The activator speeds the cure in a less than perfect joint and also can make any glue that is outside of the joint instantly cure. We use it at work with Loctite thread sealer and I use something similar at home with super glue. For fun, drip a drop (he said drip a drop, hehe) or 2 onto a small pile of baking soda or flour. It will cure instantly and rock hard. it will also get real hot if you use to much!
Old Mar 29, 2017 | 12:34 PM
redcreekauto's Avatar
redcreekauto
I need to find a new mirror for mine. Its so cloudy that it is not usable at all so when it fell off I've never replaced it.
Old Mar 29, 2017 | 12:40 PM
lasermike's Avatar
lasermike
My mirror may not be a Ford original. I've seen one just like it at the auto parts store. Wasn't too expensive if I remember right and uses the same type button that falls off on the Ford mirrors.
Michael
Old Mar 29, 2017 | 01:23 PM
Michael V's Avatar
Michael V
I've used J-B weld and had good luck with it
Old Mar 29, 2017 | 02:00 PM
PapaBearYuma
I gave the guys $10. Roughly what I paid for each of the various things I had tried...
Thanks, everybody, for the suggestions. If I have to do this again, I'll look at the IC-2000 or JB Weld.
Old Mar 29, 2017 | 04:14 PM
Tracktor's Avatar
Tracktor
I used 3m 5100 marine sealent after trying a bunch of other stuff. Lasted a year so far and won't pull of. It's good stuff to have around very permanent sealant/glue.......
RIKIL
Feb 22, 2014 06:19 PM
7.3 Rocket
21
Jan 10, 2009 06:14 PM
fairlaniac
1983 - 2012 Ranger & B-Series
Dec 29, 2007 07:27 AM
RICHARD
Nov 30, 2003 08:28 AM
