2001 f250 new to me...odd wire
Hey yall! I have been diving through the forums the last month or so after I just picked up a very clean f250 w/ the v10. So far love it. I have been talking to 5star and will be ordering a tuner and y pipe next payday.
anyways, there is a weird pulg that has been cut on the female side under the hood, drivers side, and up near the top of the headlight frame. Seems small gauged wire and i believe one of the wires is yellow w/ a black strip or dash. Any clue what this is and can it be used to power fog lights?'
is it as easy as installing a modual and you have drl?
Sadly, NOPE. I believe on this era of Super Duty, DRL equipped units utilize three relays and a resistor plugged into the connector you inquire about. The relays plug into cavities inside the fuse box where non-DRL equipped units don't have the terminals even present inside the cavities. This means there are two different complete sets of wiring harnesses which include the fuse junction boxes in question where the DRL equipped units would have the relays present, and ones without.
If you desire DRL lights on your truck, you would simply have to purchase an aftermarket add-on type kit, to make it the most cost-effective installation.
FarmingF250
12-19-2012 02:34 PM
