1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2001 f250 new to me...odd wire
Old 02-25-2017, 11:05 PM
Polie's Avatar
Polie
Polie is offline
Hey yall! I have been diving through the forums the last month or so after I just picked up a very clean f250 w/ the v10. So far love it. I have been talking to 5star and will be ordering a tuner and y pipe next payday.
anyways, there is a weird pulg that has been cut on the female side under the hood, drivers side, and up near the top of the headlight frame. Seems small gauged wire and i believe one of the wires is yellow w/ a black strip or dash. Any clue what this is and can it be used to power fog lights?'
Old 02-25-2017, 11:21 PM
Polie's Avatar
Polie
Polie is offline
Old 02-25-2017, 11:49 PM
PapaPoty's Avatar
PapaPoty
PapaPoty is offline
I believe that is for daytime running lights.
Old 02-25-2017, 11:54 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
That is the wiring connector that is to be plugged into the DRL resistor on vehicles so equipped. But because your vehicle is likely a U.S. spec vehicle (versus a Canadian spec vehicle), it has never been equipped with DRLs, therefore the plug is blocked off.
Old 02-26-2017, 10:30 AM
noober0x's Avatar
noober0x
noober0x is offline
I'm going to go find that since I have a new set of headlights that have a DRL built in...
Old 02-28-2017, 01:31 AM
Polie's Avatar
Polie
Polie is offline
is it as easy as installing a modual and you have drl?
Old 02-28-2017, 03:45 PM
m-chan68's Avatar
m-chan68
m-chan68 is offline
Sadly, NOPE. I believe on this era of Super Duty, DRL equipped units utilize three relays and a resistor plugged into the connector you inquire about. The relays plug into cavities inside the fuse box where non-DRL equipped units don't have the terminals even present inside the cavities. This means there are two different complete sets of wiring harnesses which include the fuse junction boxes in question where the DRL equipped units would have the relays present, and ones without.
If you desire DRL lights on your truck, you would simply have to purchase an aftermarket add-on type kit, to make it the most cost-effective installation.
Poonbag
2009 - 2014 F150
21
12-28-2016 10:52 PM
A/Ox4
17
08-07-2013 10:06 PM
mikey350
6.7L Power Stroke Diesel
27
04-16-2013 07:59 AM
bgalaxy67
Aftermarket Products
22
02-10-2013 11:14 AM
FarmingF250
12-19-2012 02:34 PM
Quick Reply: 2001 f250 new to me...odd wire
