Drain Plug thread pitch
Old Feb 26, 2017 | 07:15 PM
  #31
JasonB1's Avatar
JasonB1
Hmm, seems messy.
Old Feb 26, 2017 | 09:05 PM
  #32
No1Hookman's Avatar
No1Hookman
Works like magic. Actually it's physics that make it possible to do it this way. Back in the day many of the SuperDuty guys were switching to Fumotos and were changing them this way. There is NO mess as long as the vacuum is running. All it does is apply vacuum to crankcase preventing oil from draining through the drain plug.
Old Feb 26, 2017 | 09:18 PM
  #33
HRTKD's Avatar
HRTKD
Doesn't the oil get sucked into the shop vac?
Old Feb 26, 2017 | 09:23 PM
  #34
snickers104's Avatar
snickers104
subscribed
Old Feb 26, 2017 | 09:27 PM
  #35
JasonB1's Avatar
JasonB1
Ahh, OK.
Thanks for the heads-up.
Old Feb 26, 2017 | 09:34 PM
  #36
e23barton's Avatar
e23barton
I was going to call BS on this but I looked it up on youtube. Pretty amazing!
Old Feb 26, 2017 | 09:46 PM
  #37
HRTKD's Avatar
HRTKD
That's frigging awesome!!! Thanks for posting the video.
Old Feb 26, 2017 | 10:14 PM
  #38
e23barton's Avatar
e23barton
Does anyone know if the shop vac hack makes for a cleaner oil filter change as well?
Old Feb 27, 2017 | 07:49 AM
  #39
No1Hookman's Avatar
No1Hookman
Won't do you any good in that regard.
Old Oct 24, 2017 | 03:49 PM
  #40
Trustee's Avatar
Trustee
No-Spill Systems Beats Fumoto & EZ Drain
I know this is an old thread, but I wanted to pass this on:
I've long worried about a Fumoto valve opening and spilling my oil. They are made in Japan, and I just don't trust them. I found the EZ Drain, which is a Fumoto knock-off. Made in China, so forget that. And forget the Harbor Freight knock-off too. Probably the same Chinese junk.
Then I found No-Spill Systems. https://www.nospillsystems.com/
Made is USA and Canada, with a full size port for fast draining. Brass and bronze with a threaded cover and an o-ring for safety. This is the real deal that's used on 18-wheelers and commercial applications.
Check it out. Use it on my explorer and expedition and haven't looked back since. I don't have to deal with a lawn sprinkler of oil when I pull the plug and I sleep well at night knowing I'm not trusting some Chinese pot metal valve sticking down from my oil pan.
Eddie in New York
Old Nov 10, 2017 | 03:29 PM
  #41
CO Wapiti's Avatar
CO Wapiti
Eddie in New York
I agree. I have one on my 05 Dodge. These are the best! NO chance of anything catching the lever and draining the oil from your engine like the other style. I just talked with them and these units are indeed made jointly in Canada and USA.
Low profile with small bottom Part #15-14150-01
90 degree drain hose Part#CD02003
Old Nov 10, 2017 | 03:55 PM
  #42
jaxf250's Avatar
jaxf250
Nice find, thanks. Just ordered. My first OC I'll install this.
Old Nov 10, 2017 | 04:14 PM
  #43
xxxsherpa's Avatar
xxxsherpa
How much are they?
Old Nov 10, 2017 | 08:17 PM
  #44
cficare's Avatar
cficare
Looks like a good application for 18-wheelers, but I'll keep my Fumoto so I can shut off the draining without the mess of disconnecting a hose. Why? I drain my oil into a case of 2-litre bottles and need to start/stop several times when draining 13 quarts.
Old Nov 10, 2017 | 10:02 PM
  #45
brandontolentino's Avatar
brandontolentino
Wouldn't you do the same here, but just unscrew the piece enough to stop the flow, but not remove completely?
