PSOM swap compatibility
Old Feb 22, 2017 | 07:48 AM
BLDTruth's Avatar
BLDTruth
My nephew's 1995 F350 CCLB ZF5 7.3 no longer has a functioning speedometer and odometer. All of the other gauges work including the tachometer. Speed sensor in the diff is brand new. Truck drives just fine but I am guessing that is because he has a manual transmission. Assuming the PSOM is shot and needs to be replaced.
What are my options for donors? Can I pull a PSOM out of any 92-97 F Series or Bronco Aero-nose, or does it have to be a diesel cluster? Truck only has 137K original miles so finding one is going to be a little tricky.
Or is there a repair option?
Thanks in advance.
Old Feb 22, 2017 | 08:33 AM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
Check fuses first. I think it's fuse #8 that kills the speedometer.
Also do a search. Plenty of discussion in the past. Try this one.
https://www.ford-trucks.com/forums/1...ed-sensor.html
Old Feb 22, 2017 | 08:44 AM
Scndsin's Avatar
Scndsin
Originally Posted by BLDTruth
...Can I pull a PSOM out of any 92-97 F Series or Bronco Aero-nose, or does it have to be a diesel cluster? Truck only has 137K original miles so finding one is going to be a little tricky.
A respected member here who knows has said before they are all essentially the same.
I have a power stroke PSOM in my box of spares & cannot see any difference between it and 6s & V8s that I've pulled. Never taken the time to test it though.
There is a single chip that holds the mileage that can be removed from the original (de-soldered) & installed.
You would want to go with at least a 94 & up which should have the upgrade that address needle shake.
Old Feb 22, 2017 | 09:27 AM
rla2005's Avatar
rla2005
As noted above, the PSOM is common for all engines, gas & diesel. If the odometer display is completely blank verify there is power from Fuse 8 at all times and Fuse 18 when the key is in the Run position.
Here is a diagram for reference:
Check the fuses with a meter. If good, then pull the cluster and verify power is getting to the PSOM. Also inspect the PSOM for signs of cold solder joints and broken components.
I also believe you can swap the EPROM between PSOMs if you have to source a replacement.
Old Feb 22, 2017 | 09:56 AM
BLDTruth's Avatar
BLDTruth
Thank you everyone, much appreciated.
baronvonblue
Jul 31, 2018 09:24 PM
phoneman91
32
Aug 21, 2013 08:37 AM
elee3
Aug 14, 2013 12:05 PM
powersmoked
1983 - 2012 Ranger & B-Series
Feb 12, 2011 02:24 PM
D2EBMA
Jan 12, 2005 07:31 AM
