Cylinder heads
Old Feb 21, 2017 | 07:51 PM
Anderson80's Avatar
Anderson80
Cylinder heads
What would happen if I used a 1973 cylinder head with a 75.6 cc combustion chamber on one side of my motor and a 1970 cylinder head with a 77.8 cc combustion chamber on the other? It's a ford 400
Old Feb 22, 2017 | 07:00 PM
Filthy Beast's Avatar
Filthy Beast
Providing you have the intake, carb, fuel lines, distributor, plugs and wires in, etc, etc....she would run.
Old Feb 22, 2017 | 08:03 PM
LiquidCowboy's Avatar
LiquidCowboy
I agree^^^^ Should run fine, small variance in heads shouldnt hurt nor help... Should just run fine
Old Feb 25, 2017 | 05:06 PM
kopfenjager's Avatar
kopfenjager
mmm, different compression on each side isn't optimum, but like others have said, it will run.
Old Feb 25, 2017 | 07:42 PM
SDDL-UP's Avatar
SDDL-UP
Check your deck height and put the smaller chamber heads on the taller side - there could be some variation that could actually help you out. That or have the head with the larger chamber milked down a bit.
MikeMcCasland
1983 - 2012 Ranger & B-Series
16
May 24, 2008 05:39 PM
Moore558
Nov 30, 2007 07:04 PM
job1bf
Mar 30, 2007 03:56 PM
Jim59
Feb 20, 2007 02:31 PM
Art
Apr 23, 2000 09:11 AM
