Cylinder Head Identification.
Old Nov 23, 2007 | 09:22 PM
Moore558's Avatar
Moore558
Where did for put the casting numbers on their cylinder heads? I'm trying to figure out what I have on my truck.
Old Nov 24, 2007 | 04:04 AM
HemiEater's Avatar
HemiEater
if the heads are still on you might have a problem ....
Old Nov 24, 2007 | 03:58 PM
Conanski's Avatar
Conanski
If it's the truck in your signature you have E7TE castings.
Old Nov 24, 2007 | 04:31 PM
Moore558's Avatar
Moore558
I have to wonder what the engineers at Ford are smoking when they put stuff like this in bad places. Thanks guys.
Old Nov 30, 2007 | 08:45 AM
83-351cj's Avatar
83-351cj
Speaking as a Engineer, I can honestly say that most Engineers have never seen grease or a wrench. I Manage a department of 11 that build custom equipment. I make new Engineers work in assembly to learn. Most Engineers never think about ease of maintenance, hard to reach bolts, etc... Remember every thing is easy when you are looking at the drawing on a computer screen.
Old Nov 30, 2007 | 01:45 PM
MattV's Avatar
MattV
Someone correct me if I am wrong, but if you are referring to the truck in your signature, then they should be E7s which you can determine by pulling the valve cover and look for the letter T by itself.
Old Nov 30, 2007 | 07:04 PM
baddad457's Avatar
baddad457
E7's have a large "T" outside the valve cover in the lower front corner of the passenger side head. E6's have an "S" here. GT40P's have a "P" here. Your truck could also have the E6SE heads with the "S". Seen a few with em. Most got E7's. If you have earlier heads, you can only ID them by removing the intake and using a mirror to see the casting numbers.
kyle1979ford
42
Dec 2, 2018 10:13 PM
02f-350
Modular V10 (6.8l)
Aug 21, 2009 10:19 AM
micman7
Nov 14, 2007 09:31 PM
bossco30
Aug 7, 2006 08:46 PM
paul_and_ball
Oct 10, 2002 08:22 PM
