Water/meth
Old Feb 21, 2017 | 04:16 PM
spoolmonster's Avatar
spoolmonster
Water/meth
I have a 2004 f350 i was thinking about installing a water/meth kit on.I would be using it for cooling purposes and would run straight water.I have a tow tune,intake,some exhaust work and blue spring.Truck has 90,000 miles and still has stock head bolts and gaskets.Would it be safe to spray straight water for cooling?I would only use it when towing.Thanks for your time.
Old Feb 21, 2017 | 04:21 PM
nitrogen's Avatar
nitrogen
Depends on the quantity of water injected. Your ambient temperature (if it ever freezes where you live or travel straight water has this thing called freezing) if you're saving money with tap water be aware that the mineral in the water will be deposited on internal surfaces as it evaporates
Old Feb 22, 2017 | 12:57 AM
Yahiko's Avatar
Yahiko
Just use the blue washer fluid that only had water and methanol in it.
It's close to the 50/50 mix. Also you won't have to worry about freezing.
Old Feb 22, 2017 | 04:51 PM
JJ1101's Avatar
JJ1101
I use water/meth for my truck while towing for cooling purposes. I'm in Central California, so I don't have to worry about freezing. I run straight water, it's supposed to give you 40 extra horsepower. It definitely helps keep my EGT's in check. I think it helps a little with the ECT's as well. I don't tow tuned, found my MPG's go way down when I did. Those little tanks 3 and 5 gallon tanks won't get you anywhere though. I had to put in a 50 gallon tank in the bed for those long trips.
TheDuke
Aug 25, 2018 09:26 AM
greentree ford
May 22, 2013 09:15 AM
nossliw
Jul 25, 2012 11:43 AM
56 1 ton
Aug 10, 2007 11:11 AM
enduringexplorer
Apr 8, 2005 02:42 AM
