No start, no crank
Old Feb 20, 2017 | 05:00 PM
truckiescott's Avatar
truckiescott
No start, no crank
Please help. I am trying to get my son's 93 F150, 5.8 going again. There was a problem with parasitic battery drain and was fixed. The truck ran fine for a while but now it will not crank.
Symptoms - turn ignition key, fuel relay operates but no crank. Re-positioned the gear shift lever, attempted to start in Neutral...no good.
New battery (charged), new solenoid (works properly), new starter, new ignition switch. I checked all of the fuses I am aware of (under hood, under dash).
The wire (Red/Blue) going to the S Pin on the solenoid is not receiving 12v when key is turned to start position. When S-Pin is fed with a jumper the truck starts. The Red/Blue wire was traced to the ignition switch and was found to be continuous from the connection to the solenoid.
I honestly don't know where else to check. I have read the various posts and found some great info but nothing to help me from here.
Thank you in advance.
Old Feb 20, 2017 | 07:20 PM
88XLTLariat's Avatar
88XLTLariat
Check your grounds. Make sure they're clean and connections are tight.
Ddaybc
Jan 5, 2019 03:57 PM
ef150owner
Jul 28, 2012 07:06 PM
cajun1965
1997 - 2003 F150
Jun 30, 2012 04:52 PM
dirtdude007
1983 - 2012 Ranger & B-Series
25
Jan 28, 2007 05:44 PM
bcorg
Jun 1, 2006 07:51 AM
