Sponsored by: Auxito
Starting issues
Old Jun 28, 2012 | 02:17 PM
cajun1965's Avatar
cajun1965
Starting issues
2000 2WD 4.6L
I was trouble shooting why the truck will not start after it has run for awhile then sits for about an hour. I was checking the connections on the solenoid switch on the fire wall when my wrench slipped and touched both terminals on the solenoid and the engine starter kicked in. I tightened the connection then tried to start the truck with no luck. so I tried leaving the key in the "ON" position and jumped the two terminals and the truck started. Does this tell me I have a bad solenoid switch?
Old Jun 28, 2012 | 05:30 PM
Bluegrass 7's Avatar
Bluegrass 7
More probable the ignition switch.
In start position a circuit to the solenoid is completed so it cuts in the starter.
In run, that circuit is not involved.
You just by passed it at the solenoid with the igniton in run.
As soon as the crank sensor detects crank movement the PCM will apply the rest of the ignition and fuel so the motor will start.
Good luck.
Old Jun 28, 2012 | 09:05 PM
cajun1965's Avatar
cajun1965
Well I took a chance and changed out the ignition switch, no luck. The battery is good the Alt. is good, I checked all fuses and they are good, is it possible that the solenoid is bad?
Old Jun 30, 2012 | 11:09 AM
cajun1965's Avatar
cajun1965
Alright, Trying to track down the issue. when key is put in the start position the engine will not turn over I hear the relays making contact under the dash by the steering wheel. With the key in the run postion I can start the truck by jumping the solenoid on the firewall. I believe this is telling me that all circuits are closing allowing the truck to start. Could the solenoid be bad?
Old Jun 30, 2012 | 02:24 PM
Bluegrass 7
The start 'circuit' is not being 'extended' to the start relay.
You already have proven the start relay will function because it was able to close with your shunting action, the same as the start circuit is supposed to do and cranks the motor.
Use voltmeter on the lead coming from the start circuit and see if it is missing.
You can also remove both leads from the start relay and ohm it. If open it's faulty, to answer you question.
Good luck.
Old Jun 30, 2012 | 04:19 PM
cajun1965's Avatar
cajun1965
FIXED!
My hunch was right, pulled the solenoid, did not ohm test it, did not need to. when i pulled it I could hear something rattle inside. put in new solenoid and now it cranks everytime.
Old Jun 30, 2012 | 04:52 PM
Bluegrass 7
You are making us all work overtime on such an easy problem.
Good luck.
Azidan
27
Apr 20, 2019 09:42 PM
JSMskater
49
Jan 16, 2018 11:29 AM
markeyd
Feb 21, 2016 07:32 PM
Maine_Lobsterman
Mar 3, 2015 09:38 AM
89ford00
1997 - 2003 F150
19
Aug 4, 2010 12:16 AM
