Radius arm bushing types
Old Feb 19, 2017 | 05:22 PM
john jamieson's Avatar
john jamieson
I've been looking at bushings available from different suppliers. Some look to have front and rear bushings that are the same while others have one piece with a longer nipple end. Some are black, red or blue. Is one type better than the others for a stock truck?
Thanks.
john
Old Feb 19, 2017 | 05:33 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks.
john
The front and rear radius arm bushings are different.
Old Feb 20, 2017 | 03:50 PM
daveengelson's Avatar
daveengelson
Suggest review article on Polyurethane vs Rubber radius arm bushings, comes down to a matter of preference. In my cast, the 65 front end alignment was off so recently decided to replaced. Approx. 15 years earlier replaced them with 'rubber' bushings when I upgraded to front disc. brakes but I felt they should have held up better so decided to try the orange flavored Polyurethane variety. Installed with ease and pleased with the fit. Decided to change I-Beam bushing while the front suspension was disassembled.
Suggest make a list of the torque values for the front suspension components for the reassembly, certainly made a significant difference in improving front end alignment!!.
Old Feb 20, 2017 | 06:24 PM
john jamieson
Thanks for the replies. Daveengelson, by I-beam bushings are you referring to the king pins and bushings?
Old Feb 20, 2017 | 08:44 PM
daveengelson
Not sure if it's referred to as the 'axle pivot bushing', or the 'I Beam pivot bushing', it's a single bushing at the swivel point on each I Beam, DC has them listed a P/N C5TZ-3B177-A. Perhaps another member can provide part and item description. If the current bushing appear okay may consider leaving?
Old Feb 21, 2017 | 09:18 AM
NumberDummy
C5TZ-3B177-A .. Axle Pivot Bushing - 2 1/4" O.D. x 5/8" I.D.
Pivot bushing shown as 3B177 in pic:
Old Feb 21, 2017 | 06:58 PM
john jamieson
Thanks again. I wasn't really aware of that other bushing. I'm getting ready to rebuild my front suspension, so I really appriciate the info.
john
Old Feb 22, 2017 | 02:32 AM
Order and Chaos's Avatar
Order and Chaos
Something to be aware of, several types/brands of the aftermarket polyurethane suspension bushings require a special lube when installing, otherwise they can squeak like crazy. Other things to note, Most poly bushings are much stiffer than the original rubber bushings and can noticeably change the ride & handling characteristics of a vehicle, and last but not least, certain types of poly bushings do not react well when encountering petroleum based lubricants, especially ATF and old style power steering fluid.
As Dave mentioned, if you're trying to decide between the original rubber bushings and the newer poly bushings, do lots of research and reading beforehand. Personally I have no problem using poly suspension components in anything except a daily driver, the ride difference (stiffness) is negligible to me.
Old Feb 22, 2017 | 08:59 AM
6t6merc's Avatar
6t6merc
John, that axle pivot bushing can be very difficult. You will want to research the re&re techniques thoroughly. Good luck!
Eric
Old Feb 22, 2017 | 10:08 AM
Bert65's Avatar
Bert65
my axle pivot bushings fell out they were that bad. I replaced with rubber, but if you use the poly most of them say to keep the metal sleeves the old rubber bushings come in. keep track of which part came off of what side, as they look alike on the floor. I learned the hard way
Old Feb 22, 2017 | 11:00 AM
daveengelson
Not sure if they 'pivot bushing' come in Poly; if so, suggest going with the rubber, I found it to be a very tight fit so rubber may offer some flexibility? Again, torque assembly to spec's.
Old Feb 22, 2017 | 07:27 PM
john jamieson
Thanks everyone. I will deal with the pivot bushings when I dive into the suspension in a week or two.
Old Mar 24, 2017 | 12:58 AM
hoss73ford's Avatar
hoss73ford
I just finished my '66 front end today. Fortunately there is no body in it or the job would have been even more difficult. With new bushings, it's quite difficult to get everything back on as I had to pull the radius arms back with a ratchet strap & then everything went in. I went with the Energy Suspension radius arm bushings but on the pivot arms, I had 2 NOS bushings with the shells as the old ones were no good. The left side pivot arm went pretty easy but the right side I had to ream the hell out of the hole as the new bushing wouldn't press in no matter what I did (first a hammer, then my Harbor Freight bottle jack press)
I am so sore I feel like I went a few rounds on the field with Dick Butkus (Chicago Bears linebacker 1965-73) LOL.
Old Mar 24, 2017 | 07:46 AM
john jamieson
I had a nearby brake shop press my pivot arm bushings in. For $20 bucks it was worth it. There was no way that mine were going in easily.
Old Mar 24, 2017 | 08:51 AM
AZSCAWPION's Avatar
AZSCAWPION
For pivot bushings, throw the bushing in the freezer overnight, then heat the I beam with a torch. Using a ball joint press (free from most auto stores) with my impact gun they usually slip right in.
Boba Fett
Jul 7, 2014 08:36 AM
stevorino
Jun 17, 2013 06:34 AM
frodomonster
17
Oct 26, 2011 10:07 PM
Phil527
Jul 13, 2011 04:04 PM
thullz
Feb 1, 2006 12:01 PM
