Need help setting timing 74 302
Old Feb 19, 2017 | 05:00 PM
ryan73ford's Avatar
ryan73ford
Hey I have a 74 302 in a 73 F100 that I just rebuilt and am trying to get running but need help with the timing. The engine wants to start but the timing is too off there are 3 dots on the harmonic balancer that I lined the middle one up with the spot on the block and that put the rotor in the distributor close to number 1 piston, or top dead center I think it's not exact but close. as I turn it over and try to get to start it will backfire on me which makes me think the timing is still too far off. any help will be appreciated thank you
Old Feb 19, 2017 | 05:17 PM
redcreekauto's Avatar
redcreekauto
Balancers can slip. Pull the number one plug and make certain its at top dead center on the compression stroke. Even using the balancer you can be 180 degrees off.
Old Feb 19, 2017 | 05:52 PM
HIO Silver's Avatar
HIO Silver
2x... verify TDC and the reseat the dizzy so its vacuum canister is pointing directly forward and the rotor at #1. That's so ya don't run outta room while setting the timing.
Also verify the plug wires and firing order...1-5-4-2-6-3-7-8.
Btw, backfiring (through the carb) means a cylinder is firing while the intake valve is still open.
Old Feb 19, 2017 | 06:03 PM
dads1977's Avatar
dads1977
3X on verifying Top dead center cylinder # 1 then if you have to restab your distributor try to center the vacuum advance module to where you will have play to adjust left or right
If you rebuilt your motor with a 351 cam then run your spark plug wires to recommended order.
Old Feb 19, 2017 | 07:26 PM
ryan73ford's Avatar
ryan73ford
Hey thank you for the help everyone. I'll try these.
Old Feb 19, 2017 | 08:47 PM
lasermike's Avatar
lasermike
The HO VS standard firing order kicked my neighbors butt until I convinced him to switch from one to the other. It started right up after that and purred like a kitten.
Michael
oldblue1970
May 27, 2015 03:20 PM
f1001969mike
1978 - 1996 Big Bronco
May 24, 2013 02:21 PM
beasty73ford
Oct 15, 2011 11:01 PM
luke-gr
18
Nov 1, 2007 03:28 PM
Garden Spyder
Oct 30, 2007 04:10 PM
