I just bought an early 04 (01/04) and it starts hard when it's cold. It starts just fine when it's warm. It idles a little rough it seems and it's putting out white smoke, but not too thick. There are no codes on the truck.
I performed the "bubble test" and got no bubbles at all. I have found that it is common for oil rail o rings and dummy plugs go bad and I'm being told that is what the problem is.
Could the oil rail seals be the problem? It makes sense to me only because there are no codes and I feel anything else would have thrown a code. Thanks.
Just an OBD2 connector that connects to my phone. Cannot view live data. There is an EGR delete. I should have also noted that the only thing I've done to this truck is put an alternator on it and I had to charge the batteries.
If is starts fine warm then your oil rail "O" rings and dummy plugs are ok. It when it won't start warm that you have a proble with them. Welcome to FTE some really smart people here!! (Not me, )
