door latch question ?
Old Feb 18, 2017 | 09:50 PM
Leef250's Avatar
Leef250
hey all,
so my doors rattle on my 79 F250 and am wanting to fix it, so my question is, do I need to just change the door latch assembly or are there other parts that go along with it to help the doors close and latch, close properly ?
Old Feb 18, 2017 | 10:00 PM
PapaBearYuma's Avatar
PapaBearYuma
Depends on the cause. If the rubber weatherstrip is wore out, you could replace it. Dennis Carpenter rubber is the original and is good stuff. If the door is just loose, you could try adjusting the striker bolt.
Old Feb 18, 2017 | 11:51 PM
rougeriver's Avatar
rougeriver
The striker bolt should have a plastic sleeve on it. Without that sleeve, the door will tend to rattle and latch poorly. I need one for my passenger door.
David
Old Feb 19, 2017 | 04:33 AM
Matt1966's Avatar
Matt1966
Good to know!! Pulled my Doors to repair some rust and trying to adjust/align them now. Didn't know about the plastic Sleeves. Can I buy them separately or do I have to buy new Striker Bolts?
Old Feb 19, 2017 | 05:39 AM
scottscott's Avatar
scottscott
You can buy the solid sleeve separately, But I haven't figured out how to install them. You have to remove the large washer on the striker to get the solid sleeve on, but the washer won't come off.
You can use plastic tubing for the sleeve & slit it to get it on. That way you don't need to remove the washer or the striker at all.
Old Feb 19, 2017 | 08:35 AM
Matt1966's Avatar
Matt1966
Thanks for good suggestions everyone!!
Old Feb 19, 2017 | 09:19 AM
GLR's Avatar
GLR
You can get the striker bolt and sleeve at most parts stores.
I have cut the large washer off , replaced the plastic bushing, and used a flat washer to replace the one cut off.
Old Feb 19, 2017 | 10:01 AM
good to doo's Avatar
good to doo
I used a piece of 3/8" fuel line, cut a slit in it on popped it on. Works great.
Old Feb 19, 2017 | 11:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D2AZ-6522008-A = Same Right/Left striker plate:
1972/79 FoMoCo Passenger Cars except Maverick/Comet (front & rear doors on 4 door sedans/wagons); 1973/79 F100/880; 1975/86 Econoline back door.
1978/79 Bronco; 1980 T-Bird/Cougar; 1980/82 LTD/Grand Marquis/Mustang/Capri/Granada/Monarch; 1980/83 Lincoln Mark VI; 1980/86 Lincoln Town Car.
Note: Ford did not sell the nylon sleeve by itself.
Old Feb 19, 2017 | 01:17 PM
Leef250's Avatar
Leef250
thanks I'll look into getting a new sleeve for it.
Old Feb 20, 2017 | 08:43 AM
HoustonDave's Avatar
HoustonDave
Sleeves replace easily - remove the bolt and they literally slide on. They are something like $5 for several at your local store. You can fab your own from PVC but why bother if they are that easy and cheap to replace? (unless you have scrap PVC the right size already)
Old Feb 20, 2017 | 09:23 AM
GLR's Avatar
GLR
The thing is that on the 73-9s the washer will not go over the threaded part of the bolt. Replacement ones will un-screw making the sleeve replacement easy.
Old Feb 20, 2017 | 01:09 PM
CelticOne's Avatar
CelticOne
Regular User
I wrapped electrical tape to simulate the plastic sleeve. Works great.
Old Feb 20, 2017 | 01:36 PM
Ol School's Avatar
Ol School
I like 1/2" pex tubing myself. About 3/4" long and slit. Cheap and easy without
dealing with door alignment. Regardless of your fix, the sleeveless striker is probably the cause of your rattles.
Old Feb 20, 2017 | 02:15 PM
PapaBearYuma
good to know PEX tubing is good for something!
PRUSue
Feb 19, 2017 02:41 PM
glen_melton
Mar 11, 2015 04:00 PM
El_Rodney
May 10, 2009 07:52 PM
mantta
Mar 22, 2007 10:14 PM
LesPaul
Aug 5, 2003 08:09 AM
