Recovery strap hitch
Old Feb 17, 2017 | 08:09 PM
17_F350_KR's Avatar
17_F350_KR
What is everyone using in the receiver as a hook / shackle hitch etc to couple to a recovery strap? Anyone found something with a 2.5 or 3" shank that could be used without the reducer inserts?
Old Feb 17, 2017 | 08:15 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
I have always just used the pin inside the receiver hitch, even on older trucks with 2" receivers or if i have my pintle hitch in I just use that.
Old Feb 17, 2017 | 08:38 PM
K A M's Avatar
K A M
Hit ball. It's already inserted
Old Feb 17, 2017 | 09:53 PM
EpicCowlick's Avatar
EpicCowlick
I keep one of these under the back seat. It's 2 inches but I don't mind using the adapters for as often as I get this out. It takes and extra minute to use but it feels like it's an ultimate solution for strap recoveries.
Old Feb 17, 2017 | 10:07 PM
17_F350_KR's Avatar
17_F350_KR
I'll probably go with something like that shackle hitch. I have one of those for my jeep.
Old Feb 18, 2017 | 12:58 AM
DingusKhan's Avatar
DingusKhan
Use this inside the 3" empty receiver. You can also use it on the front tow hooks with no damage to the chrome or bumpers.
https://www.amazon.com/gp/product/B01ETSXUS2/ref=ox_sc_sfl_title_10?ie=UTF8&psc=1&smid=A97MONVO9R40Q https://www.amazon.com/gp/product/B01ETSXUS2/ref=ox_sc_sfl_title_10?ie=UTF8&psc=1&smid=A97MONVO9R40Q
Old Feb 18, 2017 | 11:26 AM
Oz97tj's Avatar
Oz97tj
Hitch ***** aren't designed for the shock loads of recovery. They can and will break off and become projectiles. I've seen it personally. There haven't actually been numerous deaths because of it.
DON'T USE A HITCH BALL!!!
Old Feb 18, 2017 | 02:18 PM
K A M's Avatar
K A M
Learned something new
Old Feb 18, 2017 | 02:34 PM
bowser4x4's Avatar
bowser4x4
Picked up one of these....expensive...but the machining is well done....much better than some of the ones on EBay that look like they were made with a sawzall.
Factor 55 00022-06 hitchlink 2.5 in gray | Quadratec
Fits the 2.5". Don't like having to keep anything in the truck I don't need to...so everything is now 2.5". Rated at 18000 ...more than the 7/8" schackles I have.
Bowser
Old Feb 18, 2017 | 03:28 PM
HRTKD's Avatar
HRTKD
If you don't have a recovery ring insert (like was posted above by Bowser) you could also slide your recovery strap loop into the receiver and put the pin through the loop.
I have a 2" recovery ring insert that I swap between my truck and ATV. It works well but it's nothing fancy and it certainly didn't cost $95. I would be surprised if I paid more than $20 for it.
DougJ_1997PSD
Oct 5, 2022 09:18 AM
woodsd79
Jul 14, 2020 05:10 PM
TomFL
Apr 8, 2011 12:26 AM
shark1979
Mar 16, 2009 12:31 PM
E40
All Things Towing
Jan 21, 2008 07:08 AM
