Sponsored by: Auxito
front end rebuild
Old Feb 16, 2017 | 08:32 PM
rsylvstr's Avatar
rsylvstr
front end rebuild
Yes, I've searched and read a lot. Last year I replaced my front swaybar links and wheel hubs.
Since I don't have a press (or reason to buy one other than this job) I'm looking at doing:
- loaded upper control arms
- loaded lower control arms (instead of just doing the ball joints, I want to replace the bushings also...this may be more expensive but a lot easier)
- inner and outer tie rod ends
what else? bushing wise especially...without a press.
if it is critical, then I may get them pressed out.
Old Feb 17, 2017 | 08:02 AM
rsylvstr's Avatar
rsylvstr
also, no air tools. Looking at those LCA's, they appear to be in their with limited access. 3/4" breaker bar should do it....any other advice on what to replace?
Old Feb 18, 2017 | 08:44 AM
steve(ill)'s Avatar
steve(ill)
If you buy lower ball joints local, they normally will loan you the press to push them out. It is MUCH easier to use an impact gun to do this as compared to wrenches and sockets, but can be done. Mark the location of the bolts on the upper and lower arms prior to removal... try to get as close as possible when reassemble. You will definitely need an alignment as soon as possible afterward. I have never replace the lower arm, but have done the ball joint on several trucks. Upper arms come with a new ball joint so I go that way the first time, then MOGG. Never ran into a bad bushing yet.
Old Feb 18, 2017 | 09:09 AM
rsylvstr's Avatar
rsylvstr
Thanks. So no need to replace sway bar frame bushings as PM since I'm in this thing already? Or the lower arm bushings?
Old Feb 18, 2017 | 10:20 PM
steve(ill)'s Avatar
steve(ill)
unless you see significant wear, I would not replace as a PM........ I never have replaced them.
Old Feb 20, 2017 | 06:04 AM
rsylvstr's Avatar
rsylvstr
Probably right. Looks like a real pain.
Old Feb 21, 2017 | 07:52 PM
96f150's Avatar
96f150
...Im following this too Rob...I need to do the same on my truck...I will have to take a pic and post it, becasue the rubber bushing on the upper control arms looks like its dry rotted and crumbling...maybe its still ok further in? who knows......I got scared when I looked at my bed crossmember supports the other day!!!! Going to have to fix them too!
Old Feb 21, 2017 | 07:53 PM
96f150's Avatar
96f150
Oh yeah...one more thing....STILL wouldnt trade this truck for the world! Still in Love!
Old Feb 22, 2017 | 04:53 PM
steve(ill)'s Avatar
steve(ill)
a lot of bushings (rubber) will dry and crack on the surface.. They may or may not go deep. You need to pry around and try to move the arms to see if they actually are moving or have failed bushings.
MasterPepe
Mar 7, 2017 08:15 PM
jimkari
Mar 8, 2008 10:02 PM
DesertRat1
1997 - 2003 F150
Oct 6, 2006 01:42 PM
DeadIssue
Aerostar
May 22, 2006 10:53 AM
mnm99
1978 - 1996 Big Bronco
Apr 9, 2003 12:33 PM
