Fuel tank vent (Ty's version)
Old Feb 15, 2017 | 08:34 PM
ty_rod's Avatar
ty_rod
This is my version of doing the fuel tank vent mod. Problems included taking forever to fuel up, and fuel spilling out.
Here is the OEM vent and filler, I'm guessing fuel was suppose to enter the tank thru the center hose and vent out around it, but it sucks.
Tear out the insert inside the filler neck, I tried a chisel and vice grips, that didn't work, had to sawall it out, as a member mentioned in another 'how to'.
Once you have it out, drill a big enough hole to install a hose fitting, screw it in part way, I choose to follow another guys 'how to' and also epoxy my fitting on. I went with 5/8" hose fittings.
I read other 'how to' where they use the roll over vent hole, but some have ran into fuel tank vacuum issues. I went with a bulk head fitting designed for A/C systems, with a 90 degree 5/8" hose fitting, but....you have to drill into your tank.
I found an old coffee cup, stuffed it inside the tank, held it inside with one hand to catch the shavings, or most of it.
While I had the bed off, I did the F26D rear fuel tank swap as well, here's where I drilled on the rear tank, the bed crossmembers are close on the rear tank, it was a squeeze but still worked.
I haven't tried fueling up yet, as I am still cleaning up some wiring splices that the previous owner did for a gooseneck. I will do an update soon.
Old Feb 16, 2017 | 09:41 AM
BBslider001's Avatar
BBslider001
Nice work! I really wanna do one like this. I HATE filling up. I like it, but I hate it...LOL
Old Feb 16, 2017 | 10:03 AM
knottyrope's Avatar
knottyrope
I need this done on my rear tank, I am tired of it spitting out fuel on me. nice pics on your write up
is that a Viton oring on your bung fiting?
Old Feb 16, 2017 | 11:18 AM
oldbird1965's Avatar
oldbird1965
This mod is a MUST! Especially if you pull a trailer and don't have a choice except to fill up at the truck pumps!
Old Feb 16, 2017 | 04:32 PM
ty_rod's Avatar
ty_rod
I'm not sure, the O-ring came with fitting. Here's the part number for future reference: A/C Hose Fitting FT 1797C
eBay link: http://www.ebay.com/itm/New-A-C-Hose...-/162054205629
Old Feb 16, 2017 | 05:55 PM
pwjackson42's Avatar
pwjackson42
I really like the use of the bulkhead fitting. I bought new rollover valve seals and used a 3/4 npt to 3/4 hose barb fitting in place of the rollover valve. Has worked great so far and I can fill my 38 gallon rear tank as fast as I want and I believe since the vent is clear on top I can get about 40 gallons in it!
Old Feb 16, 2017 | 07:13 PM
ty_rod's Avatar
ty_rod
Went to the big rig pumps today, WOW! No more shut off or fuel spilling out. My only gripe was that I put in 19 gallons, which should be half a tank, but the gauge showed little over a quarter, I extended the level sensor wire, but it must be off. Other than that, it was definitely worth it.
Old Feb 16, 2017 | 08:30 PM
redman84's Avatar
redman84
Did you use our original seals? I assume your fitting is a 90° and it fits nicely into the seal?
My rear tank has a 3/4" rollover valve from I think a c&c truck but there's no more to be found so I think pipe fittings are my best option for the front tank.
Old Feb 17, 2017 | 03:13 PM
pwjackson42
I bought new seals from ford and used plastic 90's. I took my chain saw chain grinder and made a little groove for the fitting to seat on the seal. I don't think I have had any leaks yet. Been on there 6 months or so now.
Old Mar 26, 2017 | 09:30 AM
Peter A.'s Avatar
Peter A.
Good morning,
Ive got the same problem. Sent you a PM with some technical questions.
Thanks
Peter A.
FordF350Baby
Apr 21, 2020 09:16 PM
tbirdage
Apr 2, 2017 09:33 AM
Lukes66
17
Sep 8, 2016 06:35 PM
wdhille
Sep 30, 2009 07:09 AM
rideracelivemx7
Jul 25, 2009 03:35 PM
