shakes, poor throttle response, starving?
05 F350 6.0, 164,000 miles
I couldn't wait to drive it again, I spent hours detailing and cleaning. Well I go to start and noticed it struggled to start, and didnt seem to be idling right. I looked under the hood and it was leaking fuel from the Regulator. I left it parked and never drove it since he last did. I read around on these forums and I bought the blue spring upgrade kit.
Now I notice it shakes at idle a lot more than it used to, pretty bad at times. Then upon driving it shakes even worse upon acceleration attempts, and has very poor throttle response. I have to put it nearly to the floor and even then the acceleration is nothing like it used to be. Most of my trip was highway at 60mph, and anytime it would start climbing a hill it would shake pretty bad with the acceleration. When i let off the gas to slow down before braking it stopped the shaking.
So I read around on here and I went back and used the factory bowl and valve for the regulator, still had the issue.
Next I went back and replaced the blue spring with the original, still have the issue.
I just checked the FICM and it is reading between 48-49 during key on, cycle, and cranking.
Batteries are great
Alternator only reads 13.6 at 2k rpm idle, but have not had charging issues.
My father says he never noticed anything wrong with it other than it occasionally missing out. But I don't see how changing the fuel pressure regulator would have caused this. Especially since I tried every combination of oem and aftermarket parts, ensuring that all the connections and parts were installed correctly.
Any thoughts and input would be appreciated. I would like to rule out the basics and fixes I can do before I have to pay for someone else to fix it.
As far as parts replaced, I first replaced everything from the full kit, except for the housing.
Next I tried with only aftermarket seals and blue spring( Factory housing, bowl, bleeder valve, bolts) I did notice that the factory seal from the valve was stuck in the hole to the filter area, I had to force it out from inside the filter area. I used the new seal with the factory bleeder.
then I just replaced the blue spring with old factory seal. Now the only new parts on the regulator are the seals.
- How long ago were the fuel filters replaced with Motorcraft filters?
- How long ago was oil change and Motorcraft oil filter? Which oil?
- Have you researched "stiction"?
- Exhaust Back Pressure Sensor is right next to the thermostat housing, it has metal tube connection going down to the exhaust manifold - that tube needs to be inspected to ensure that it is not clogged. Acceleration start with the go pedal, then command from ECM for more fuel, then EBP responds with increase in pressure - then ECM asks for more air from the Turbo... No EBP response then no turbo then little to no acceleration
- Everyone is about to ask you for computer codes and values so you need a scan tool that can monitor live data. With a scanner and live data, we can determine if the EBP is functioning and balanced as well as all the other sensors - blind without a scanner and live data.
New fuel filters ordered, last replaced at 138,000 miles. Only use motorcraft fuel and oil filters
Oil and filters changed 700 miles ago, oil was quaker state full syn 5w-40 I believe.
I have wondered about stiction, is REV-X worth a try?
I do not have a scanner, deciding now to keep the truck I will have to buy one.
What are your opinions on Motorcraft and K&N filters? I could get one today if they are acceptable to use.
Heading to Oreilly to pick up the FD4616 right now, and will install tonight. How long should it take to see a difference if this was in fact the issue?
Last edited by WatsonR; Feb 15, 2017 at 05:42 PM. Reason: Wrong filter, your buying a fuel filter, I gave the oil filter
