61-63 460 swap
61-63 460 swap
Hello I did a search in this forum trying to find some pics of what guys who have 61-63 f100 do for mounting when to come to installing a 460 in our trucks. Normally it would be bolt on but since 61-63 had the mounting on the front cross member you have to install a cross member or use one of the other mounting solutions. What im looking for is pictures and review from people who have done it and what kit the used and how they like it so far.
Thank you for your time
Trans-Dapt, as well as other sources, offers bolt in cross members for both engine and transmission. These will mount the engine and trans as factory and get away from the mounts your truck has.
Check with any of the suppliers that support this site. Most will offer something along these lines.
Don't have any pictures, but I have used these mounts on numerous swaps over the years and never had any issues. Even used them to put a 429 / C6 into a '70 International Travelall years back.
One thing to be aware of. There will most likely be interference between the new transmission bell housing and a cross member. Some just remove this cross member. I prefer to rework it since it helps pick up the rear mounting points for the front leaf springs.
Good luck.
Good luck.
Here is a link to a Trans Dapt engine cross member that Summit carries.
https://www.summitracing.com/parts/trd-9313
Good luck
Good luck
thank you for the link I have seen this one before. one you slide the ends on did you weld them in place? Also did you bolt yours to the frame by drilling new holes or weld it ?
Is there another way to secure the ends
61FordUni
1961 - 1963 F100 Unibody
02-19-2015 08:41 PM
79MudRat!
11-12-2012 07:28 PM
61Stepside
09-15-2003 10:43 AM
