Most Recent Recalls
Old Feb 13, 2017 | 12:22 PM
RV_Tech's Avatar
RV_Tech
Most Recent Recalls
Here are the most recent recalls as posted on RV Business
Jayco is recalling 93 2017 Seismic and Seismic Wave fifth-wheel recreational trailers equipped with hydraulic brakes. In the affected vehicles, the break away switch may not be properly wired.
Jayco Inc. is recalling 25 2017 Eagle fifth-wheel recreational vehicles equipped with the dry camping option. In the affected vehicles, the LP manifold was mounted to the fifth-wheel frame directly above the axle assembly and the suspension U-bolts. Impact from the axle can crack the LP manifold resulting in a propane gas leak.
Forest River is recalling six 2017 XLR fifth-wheel recreational vehicles. These vehicles have a Federal Placard that identifies the vehicle as a “Travel Trailer” when the placard should state “Fifth-Wheel.” Also, the VIN does not correspond to the type of vehicle. As such, these vehicles fail to comply with the requirements of 49 CFR Part 567, “Certification.”
Steve
bobj49f2
45
Dec 13, 2024 07:45 AM
Connecticut Calvin
71
Oct 4, 2023 01:42 PM
Miranda Creech
May 28, 2018 08:39 AM
Franklin2
Sep 23, 2002 12:41 AM
Ball
Sep 22, 2002 03:47 PM
