6.2L V8 Discuss the 6.2L V8
Remote Start Issue
Old Feb 13, 2017 | 08:44 AM
Danstrans's Avatar
Danstrans
Remote Start Issue
newbie here first post and not sure if this is the right place for this post
i have a 2016 F-250 6.2 with the remote start, when the truck sits all night the key fobs will not work the next morning it's like it is on sleep mode it will not unlock or lock and remote start will not work unless i go to the truck and press the key pad and i push 7/8-9/0 together then from there everything works, very frustrating to have this option and having to walk out and start it worked fine for the 1st few weeks, just wanted to see if anyone else is having this problem
Thanks love this forum a lot of good info here
Old Feb 13, 2017 | 08:54 AM
WyoBull's Avatar
WyoBull
I have the same truck configuration and I have not had this problem at all with the keyfob not working. You might try changing the battery in the fob? Could be that you got some bad batteries. That would be where I would start and if that does not work, maybe the dealer can flash it or something.
I know you have to hit the lock button once and then hit the remote start button twice to remote start it.
Old Feb 13, 2017 | 08:56 AM
brickman's Avatar
brickman
May need new battery in fob, I had to replace the one in ours last year
Old Feb 13, 2017 | 04:53 PM
Danstrans's Avatar
Danstrans
thanks guys
i will try a new battery
Old Feb 14, 2017 | 09:06 AM
Tarster's Avatar
Tarster
Just as a side note, not sure if the newer keys loose their programming like the older ones do.. but here is a guide to re-program on the newer trucks, Ignore the F150 in the url bit I clicked on F-series trucks and then 2014.
2014 Ford F-150 Key Programming - Free Keyless Entry Remote Key Fob Programming Instructions
Old Feb 14, 2017 | 11:11 AM
Danstrans's Avatar
Danstrans
i will give it a try, i don't feel it's the batteries it seem like the truck goes into sleep mode it just happens in the morning and the rest of the day it works fine, i had a 2016 F-350 diesel and the same thing happened didn't work in the morning but was fine the rest of the day
JEB63
Jan 26, 2019 05:04 PM
dh_meyer
2009 - 2014 F150
Jan 6, 2017 07:48 AM
Redneckmedic2009
Electrical Systems/Wiring
Nov 2, 2014 12:54 PM
BURNSTOUGHFORD
2009 - 2014 F150
24
Feb 16, 2013 06:58 AM
ictbu
Sep 18, 2006 11:00 PM
