Bronco Quarter Panel Replacement
Old Feb 12, 2017 | 01:24 PM
NewEnglander's Avatar
NewEnglander
Hey All,
I've had the Bronco kind of put away for a while, I've been doing rear quarter panel replacement when I've had the time. I have the new panel tack welded up but I'm not sure if I should fill every single gap with a bead? It just seems like it's to time consuming and I suck at welding.
I was thinking now that its welded up I could grind it all down and then do fiberglass filler. Any opinions?
Doing the first rough cut.
Lining it all up
Welded in place
Old Feb 17, 2017 | 09:10 PM
FuzzFace2's Avatar
FuzzFace2
You should fill it all in then grind it smooth.
Moving all over when grinding like you do for welding to keep from warping the panel.
Dave ----
Old Feb 19, 2017 | 07:18 PM
NewEnglander
Thanks Dave. I'm going to spend more time on it tomorrow filling everything in.
NewEnglander
1978 - 1996 Big Bronco
Feb 12, 2017 01:23 PM
73highboy4x4
Paint & Bodywork
Jan 19, 2013 10:07 AM
tommyleea
Paint & Bodywork
Mar 28, 2007 09:37 PM
SproutW
May 6, 2004 06:08 AM
roscoe
Paint & Bodywork
Oct 12, 2000 10:04 AM
