How hard is it to replace front differential?
Old Feb 12, 2017 | 09:16 AM
Byoung Oh's Avatar
Byoung Oh
I bought a 4x4 Ranger with different gear ratio in front and back.
The original differential is 3.73 but mechanics fixed this truck before I bought installed 4.10 in rear.
I found that front differential assembly is cheaper than the rear and the rear already has new backing plate, brake shoes and hardware installed. So I am thinking replacing front to match rear.
How hard is it to do so?
I could not find any instruction showing the steps.
Do I have to completely remove front axle (cv joint) out or is it possible to just push them out of the way without removing entire axle?
Looking at some service manual, it seems removing steering knuckle is needed in order to remove the axle completely, which I want to avoid if possible.
Old Feb 12, 2017 | 09:55 AM
Conanski's Avatar
Conanski
What year is the truck?
Old Feb 12, 2017 | 09:58 AM
Byoung Oh's Avatar
Byoung Oh
2000.
Ranger XLT 4X4 flareside
Old Feb 12, 2017 | 11:06 AM
Conanski's Avatar
Conanski
It is a pretty involved job on that truck, the CV drive axles on both sides have to come out first which means much of the front suspension has to be disassembled.
Old Feb 12, 2017 | 04:49 PM
Byoung Oh's Avatar
Byoung Oh
I was hopping that was not the case..
Will I have to remove the axle completely?
It looks like I have to remove steering knuckle, axle, and front drive shaft.
Anything else in the way?
I found used one on eBay for less than $100 with shipping. Which I think is a great price.
But I have a lot more things to fix on this truck..
Old Feb 13, 2017 | 08:29 PM
Conanski's Avatar
Conanski
Post a link to the item you found.
Old Feb 13, 2017 | 09:12 PM
Byoung Oh's Avatar
Byoung Oh
CARRIER FRONT AXLE 4.10 RATIO FITS 98-11 RANGER 247388 | eBay
Looks good in the picture. Probably should change seals just in case.
But, this is least of my priority now because there are more things that needs to be fixed. Have to replace rusted out rear doors and either weld holes or replace catalytic converter.
Old Feb 17, 2017 | 07:36 AM
02FX4Dude's Avatar
02FX4Dude
Difficulty is relative to your skills, experience, and tools available.
You would need to:
remove hubs
separate top ball joint from knuckle
separate tie rod ends from knuckle, probably
tilt steering knuckle aside to remove CV's, or separate the lower ball joint if desired.
remove front driveshaft
remove fasteners holding front diff to frame
Inspect steering/suspension components and replace if necessary
Install is opposite of removal
I've done this in my driveway, on jack stands, with hand tools.
I would say if you've done steering suspension work before and don't have any problems with seized fasteners, 3-4 hours working casually to remove the diff, and probably similar to re-install. If you've never done some of the stuff listed above it might be more time. A motivated person with experience could probably do it in half the time.
Old Feb 17, 2017 | 07:27 PM
Byoung Oh's Avatar
Byoung Oh
You would need to:
remove hubs
Sounds like it is doable. I've done all of those before and my only worry is rusted and seized bolts + bad back I have...
How heavy was the differential? Were you able to lift it up in the place with out help of floor jack? I'm asking because my floor jack doesn't go high enough. I could put some blocks under the jack if I have to.
Old Feb 20, 2017 | 06:49 AM
02FX4Dude's Avatar
02FX4Dude
I think it was about 50-60lbs, you'll probably want a jack or a second set of hands to do the job. I had a motorcycle jack to use but a floor jack with a wide board would have worked well also.
brian931
Feb 21, 2010 10:24 PM
ddogg126
Bronco II
Feb 28, 2005 11:30 PM
fastfalcon64
Jan 23, 2005 02:32 PM
cactusbronco
1978 - 1996 Big Bronco
Jan 2, 2004 10:47 PM
shaun fom manchester
Sep 13, 2003 09:02 AM
