Do you think it's safe...
Old Feb 11, 2017 | 10:42 AM
Norton72's Avatar
Norton72
To use an impact wrench on the HFCM filter cap? Somebody put that sucker on waaaay too tight.
Old Feb 11, 2017 | 10:59 AM
Norton72's Avatar
Norton72
I tried it with 120lbs. of pressure and that didn't work, even with long bursts. I'm going to crank the pressure up a bit.
Old Feb 11, 2017 | 11:07 AM
87crewdually's Avatar
87crewdually
It's easy enough to disconnect the fuel lines, electrical plugs, and unbolt it from the frame. Throw it in the bench vise to get it apart. While it's out clean it.
Old Feb 11, 2017 | 11:14 AM
Per4mance's Avatar
Per4mance
X2 on that one. Might cost ya more in aggravation and money if you don't.
Old Feb 11, 2017 | 12:11 PM
Norton72's Avatar
Norton72
I got it off with 150 lbs. It was still hard to turn after it broke loose. The filter didn't come out with the cap, but it wasn't hard to remove. The fuel looked good, I cleaned everything up. This truck looks amazing underneath. Everything is in place just like it came from the factory. Under the hood as well.
Old Feb 11, 2017 | 01:02 PM
Bumblebee04's Avatar
Bumblebee04
Whenever I run into something fuel related that is a PIA to get apart i use a heat gun. Also works great on a part that you dont want to discolor/distort the surface on vs using a torch. Takes a bit longer but normally gets the job done.
Old Feb 11, 2017 | 01:30 PM
diesel_dan's Avatar
diesel_dan
Sage advice: heat expands/cold contracts. Heat the thing with the inner threads and cool the thing with the inner threads.
Jude: put some silicone grease on those threads when you slap it together, also lube the o-ring...
Old Feb 12, 2017 | 04:44 AM
Yahiko's Avatar
Yahiko
If I recall correctly silicone grease is not something you want in the
fuel system. I would just stick with clean engine oil of diesel as
a lube for the threads and O-ring.
Old Feb 12, 2017 | 07:27 AM
jsm180's Avatar
jsm180
Warm it to remove and fuel lube on the threads. Now it's called EZ Turn.
https://www.aircraftspruce.com/pages...ezturnlube.php
540milotalon
Aug 4, 2011 11:57 PM
whisler
Oct 5, 2010 02:36 PM
vloney
6.4L Power Stroke Diesel
58
Feb 24, 2010 06:27 PM
Crappie Buster
Feb 10, 2009 07:31 AM
carpe_diem
Mar 31, 2003 05:08 AM
